Question about Maytag Neptune FAV6800AW Top Load Washer
What does Ob means? - Maytag Neptune FAV6800AW Top Load Washer
  • dh1200s
    dh1200s May 11, 2010
    Hey Joanne, Can you verify your Machine Model number? If it's a FAV6800AW or FAV9800AW could the error code on the Console be "od" or "OP"? If it's the above model type I will try to help.
  • yadayada
    yadayada May 11, 2010
    out of bounds?
    President:
  • 1,304 Answers
Out of balance
you may ned to get the clutch replacedx here
but try releveling the machine
Posted on Oct 07, 2009
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore/Whirlpool Off Balace ob code problem with empty machine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^@#$
Jan 07, 2010 | Kenmore Elite HE4 Electric Dryer
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso code ob
Code "OB" means Off Balance.
Oct 17, 2009 | Kenmore Washing Machines
Washer says "ob" and there aren't any clothes in the washer
some machines can be over loaded and under loaded u need to take the clothes out and run it with nothing in if it does it again with nothing in the sensors are faulty and u need an expert to check it for u
Jul 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
EPSON DFX-9000 ERROR CODE = OD and OB
error code OB turn off the printer, why?
Sep 17, 2008 | Epson DFX-9000 Matrix Printer
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Maytag Neptune FAV6800AW Top Load Washer Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
