I have a Vizio GV47L that made a pop sound and now has no picture or sound. If I unplug it, then plug it back in, the lights light up on the bottom and when I press the power button, the buttons iluminate, but do not function. From what I've read, it seems like either the power board or main board, but I'm not sure how to determine which might be faulty. Does anyone know a simple way to determine which might be bad. I'm prepared to just replace the whole part, but want to try to avoid ordering the wrong one. Thanks for any assistance you can provide.
Most likely the pop sound was a capacitor exploding on the power supply board. There is the risk that the power supply damaged the main board when it failed. The best solution would be just to replace the failed cap and see if the TV will start normally.
I have a Vizio GV47L LCD TV, and my SR605 could not control it. Does anyone has the remote control...
(More)
I have a Vizio GV47L LCD TV, and my SR605 could not control it. Does anyone has the remote control code for this TV? Thanks.The codes from SR605 manual, 0864, 0885, and 1756 did not work.
picture went blank, now TV won't respond to any command and screen is black. I unplugged then...
(More)
picture went blank, now TV won't respond to any command and screen is black. I unplugged then plugged back in to ''reboot'', but to no avail. Control lights on front of TV stay lit, but that's all. It's dead to any and all commands, from any remote, and the on-board control points won't function either. TV is 2-1/2 years old. This is first problem.
slight buzzing from back right of set Picture brightness flickers and is somewhat dimmer apparently...
(More)
slight buzzing from back right of set Picture brightness flickers and is somewhat dimmer apparently in the backlight system somewhere, don't see where others have had this issue... TV still displays pictures on all inputs, no problem with sound
My vizio gv47l went off the other night and now will not power up . i unplugged it and plugged it...
(More)
My vizio gv47l went off the other night and now will not power up . i unplugged it and plugged it back in the lights light up for about 30 seconds then they go off. the remote will not work as well
