Question about Linksys Wireless-G Broadband Router
I connected a laptop, however it got stolen, so I have a new laptop, how do I start over with my linksys system? should I just connect the proper wires and use the cd as if I had never done this before?
  • Linksys Master
  • 6,487 Answers
Yes that will be better since you have a new laptop , so better reconfigure everything like you have a new system....
Posted on Oct 07, 2009
  • 11,800 Answers
No. All you have to do is to go to Start / Control Panel / Wireless network Setup wizard, open it, follow it, select your router and input your router's password - if you had one.
How to replace linksys-g home router with linksys e3000
Use the laptop with a network cable to check connection. Just connect the NEW? e3000 to the ISP modem. It should work right from the start. If the e3000 is not new, there is a reset in the back.Hold it till it cycles.
The wireless on the laptop should pick up the new router as a new network.
You can even go further back by cycling the ISP modem as well.
Oct 16, 2012 | Linksys Wireless-G WRT54G Router
New router says "unable to connect to computer, registration completed.
I really need more information. If I assume you know nothing about this, I can start by asking if you have a modem connected to the router? If so, need to check if it is connected properly. Next I would have to know if you are connecting wirelessly to a laptop or wired to a desktop. If it is a laptop, you must have either an internal or external network card installed. I would be happy to help further if you give me more info.
Aug 24, 2010 | Linksys Wireless-G WRT54G Router
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
Im hooking everything up right as im going through the 4 step intallation disk and it says Your new router does not appear to be connected properly.
make sure the cable going from your laptop/computer is connected - you NEED to be connected! or if you are going wireless and you know that your laptop wireless adapter is working and you can see the default wireless network - which is "linksys" (without the quotes) you should be able to connect to it and configure it without the CD..
Dec 30, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
I cannot make a wireless connection my new laptop to the linksys router. My homenetwork works and my first laptop is connected to a wireless linksys connection. when adding another laptop I cannot make a...
then it's the second computer's problem, try repairing the connection, turning the wireless switch on and off, rebooting, and if your using vista use windows system file checker
or if xp, put this in either command prompt or run
chkdsk /r
Sep 30, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
One card interfering with other connections
Have you checked to make sure the laptop wireless NIC isn't acting as an AP by mistake? That could explain both desktop and laptop connectivity issues. Just a thought.
Jan 29, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
CONNECTIVITY
Your new laptop,
Are you searching for a new wireless network? Then your router doesn't show up on the list of networks?
I can rephrase if need be.
Oct 18, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
55 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
