Spin cycle does not evacuate enough water, have to run the spin a second time
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Clean out the filter then try..Good luck
Posted on Oct 07, 2009
Ny front load neptune washer comes to the spin cycle and the door unlocks and it won't spin or empty the water. Is it the inlet valve? Or what?
Janie,
It sounds like your evacuation pump is clogged, and needs cleaning or needs to be replaced. Some front loaders have a clean out in the front lower left of the machine 's cabinet. You'd need to check with your mfg owners manual to see if your model has a clean out for the evacuation pump which pumps the water out of the machine.
Old rubberized bathroom carpets, and other fraying items like towels torn into rags, can lose enough material to clog up the pump impeller or freeze it until the motor burns out trying to turn against a bunch of foreign materials like these.
It's a nice washer and worth the repair and note of caution once you get it fixed.
Cheers,
Kelly
Commercial and Residential Facility/Property Manager
San Diego, CA
Jan 17, 2015 | Maytag Neptune MAH5500B Front Load Washer
My Whirlpool spins... It just does not do a very good job
It's very possible that the impeller in the drain pump is striping out and not allowing the pump to get up to high enough spin to completely drain.
Jan 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
When turn to spind ry it just dont do the work
Your empty pump filter is probably blocked. Not enough water getting evacuated when it empties so the spin cycle wont run. The filter is probably on the front of the machine at the bottom (probably behind a little door).
Locate, clean, reassemble, job probably done
Jun 23, 2011 | Speed Queen CTSA0AWN Front Load Washer
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Dec 22, 2009 | Washing Machines
Water doesn't drain
I suspect you have a failed water pump. It evacuates the tub during the cycle and is located at the bottom of the washer. If this is the case, you will hear the motor running like it is getting ready to go into the rinse/spin cycle if not then the problem is likely to be in your cycle timer on the console.
Feb 23, 2009 | Washing Machines
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
