Question about Microsoft Xbox 360 Console
RRD Hello i have the RRD LED come on but the right Quadrant starts with red till the last Quadrant been the left top is dark i've never seen this i've tryed all the fixs but nothing works to get this going again can you tell me what this could be or am i DOOMED. Carmelo Thank you
  • 42 Answers
I unhook everything and cleaned the system and it worked fine
Posted on Oct 07, 2009
Looking fo wiring diagram for harness from pioneer deh- 2800mp to 1999 dodge dakota
Hello my name is Israel and I will be glad to help you. Please be sure to rate the solution. Good Luck. The diagram for the 99 Dodge Dakota:
Constant 12V+ Red/Blue Switched 12V+ Red/White Ground n/a Illumination Black/Yellow Dimmer Orange Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Brown/Yellow Right Front (-) Brown/Light Blue Rear Speakers 5 1/4" Rear Corners Left Rear (+) White Left Rear (-) Dark Blue/Red Right Rear (+) Brown/White Right Rear (-) Brown/Orange
This is for the stereo:
Sep 13, 2011 | Pioneer DEH-2800MP CD Player
I need a manual for my gigabyte ga-t671mg motherboard so that i can connect the on /off switch
There isn't a manual available for it, as it is an OEM motherboard in pre-built PCs BUT I've the same motherboard in a Packard Bell iMedia J2422 (now in a BitFenix Colossus case!). You connect the power to the bottom left, reset top left, h.d.d led top right, power led bottom right into the Front Headers (F_Panel) - which is located on the bottom right hand-side of the motherboard. My board has writing underneath the header telling you what connects where, maybe yours does too? Hope I've helped.
Mar 24, 2011 | Intel Motherboard
After clearing a paper jam when you print the right side of the printed paper is not as dark as the rest of the page. I have replaced the fuser to no avail is there an adjustment that needs to be made?
Hi there! Wich color is not dark as the rest?Only when you print in black and white or even in the color printing? If the black or any of the colors are not dark as the rest of the page you must clean the led scanners(Wehn you open the top cover you will see long black boxes on the top cover,those are the led scanners) if they are clean then your transfer belt is damaged and can`t transfer the image from the drums to the paper.You can check the belt by starting a printing and open the top cover while the paper is moving under the toner cartridges and look at the page!Please replay what you have seen so i can help you futher!Thaky for usin Fixya.
Nov 29, 2010 | OKI C5200n Laser Printer
Hi, just wanted to know if there is a diagram for the head unit. the colours for the left & right speakers in a ve ute?
*Remove drivers side centre console panel
*You'll see a black plug on the "side" of the stereo, this is your speaker outputs and constant 12v+.
Dark Green - / Light Green + = Front Right Speaker
Grey - / Brown + = Front Left Speaker
Light Blue - / Dark Blue + = Rear Right Speaker
Yellow/Red - / Brown + = Rear Right Speaker
Sep 21, 2010 | Car Audio & Video
How do i get my red eye fixed
First make sure how many lights are red, red ring of death with light up the player 1,3,and 4 slots. If all 4 are glowing try an av cable (sometimes rrd will look like all 4 are lit but look carefully and often the fourth slot is only reflected light). next log onto http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair and enter your console information. If the rrd warranty is still active, they will repair it for free (rrd is warranteed far beyond the normal console warranty, so be sure to try this before opening your console).
Mar 01, 2010 | Microsoft Xbox 360 Console
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
I need color codes
Constant 12V+ Black/Yellow
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
Top left and bottom right images/letters distorted.
I can fix it for $325? 213 880 1795
It was a convergence problem, both chips goes bad bad also look for bad resistors around the circuit? This is not an easy repair for non skilled person? You need to realign it after replacing the chips? Don't be cheap pay someone to do it right?
Oct 02, 2008 | Sony KP-53XBR45 53" Rear Projection...
Screen problem
I think try going to display setting under control panel. See if it allows you to change to full screen mode.
Sep 17, 2008 | Compaq Presario X1000 Notebook
53UWX10B
Good Day, Butchilee,
Sounds like you have patience, hope your TV has some trace left. Hit recommends that you replace the originals with
STK-392-150's and the resistors. Replace said items with care then back down on the screen/ focus controls and gradually bring the screens up until you have pic, adjust focus. Go into customer menu and adjust color down, set brightness to 50%, contrast to 100%. Then go back and adjust the screens for proper, black/white, tracking. AND It's best to double check the soldering connections.
Good Luck, Big Irish.
Jul 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
