Question about Kenmore 67082 Electric Dryer
Kenmore 67082 "PF" power failure code
I have a Kenmore Elite Oasis dyer that have given a "PF" power failure code. The manual said to hold the start button to reset the dyer. All this does is make a beeping and shows the "PF" again. The dryer is a year and a half old. Any suggestions on what to check before we call a repair service? Thanks
  • 1 more comment
  • Kalen Dec 24, 2007
    We reset the breaker and the dryer is still giving the "PF" power failure code. It will not reset when the start button is held down, it just beeps and flashes the "PF" again.
    Any other suggestions?
    Thank you
  • janfrew Oct 08, 2008
    I have a kenmore HE2 and after about 10 minutes it stops and flashes "PF". I have to turn it back on a few times before it finishes the load. I know this will lead to total system failure! I hope someone can help!
  • bernigreat Dec 09, 2008
    same problem! the dryer runs for a about 10 min and then shows 'PF'. It's completely dead for about 10min - no way to bring it back. After that I can start it again. It's like it's over heating or has a humidity build up somehwere. The actual power looks fine , however. I measured it. Recenlty I witnessed it failing. The display started flickering a little for a few seconds and then it died.
    Scholar:
  • 146 Answers
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Posted on Dec 24, 2007
  • Kelly Sullivan Dec 25, 2007
    Check the thermal fuse in the back of the dryer. It is located under the rear panel usually on the blower assm. It is about 3 inches long, white, and has 2 wires coming to it.
I have Kenmore elite oasis electric dryer when you push start button it goes to pf code ive tryed holding down start button & it just flashes & is back to pf code how do I reset it ?
try unplugging it from power or tripping the circuit breaker(which might be easier). then re energize it and see if it resets. good luck.
Jul 29, 2016 | Kenmore Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Mi secadora electrica oasis kenmore elite aparece un codigo PF que significa eso como puedo resolverlo
PF means power Failure unplug hold the cancel button for 3-5 seconds if the pf doesnt disappear then unplug the unit for 7 minutes this will make the control reset on the board if the pf still doesnt fade then you would have a control issue and most likely have to replace the control or call a technician if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Feb 26, 2011 | Kenmore Elite Oasis 6809 Electric Dryer
PF error code on kenmore elite
PF stands for Power Failure. Caused by unplugging and plugging in within 30 seconds, or a short power surge or outage.
Dec 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The Dryer is working but stopped in mid cycle and gave me a code of PF
Power Failure. Press and hold start to restart dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 04, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 110.67087600 Dryer will not power up. No power at all. Prior to this it had a PF flashing. House power checked good.
If no-go.. the timer is failed due to a power spike and must be replaced.
Apr 26, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
What is the kenmore washer model # 21086 water pump failure error code
Aug 16, 2009 | Kenmore Elite 21086
PF(Power Failure) error appears each time the washer starts.
PF simply means there was a power failure since the last time you used the machine.
To clear it - simply power cycle it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 67082 Electric Dryer Logo
1,859 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
