Brown spots after wash - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Sounds like oil from drum bearing s which would also be noisy on the spin
Posted on Oct 07, 2009
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Leaving brown stains on clothes, messing them up,
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
May 09, 2010 | Washing Machines
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Brown spots on clothes from my maytag neptune
this sounds very much like that the bearings have badly worn-out,pain to replace them ?
Jul 13, 2009 | Washing Machines
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
BROWN GREASY RESIDUE LEFT IN BOTTOM AND TOP OF TUB
could be the transmission shaft rubber seal...need to call service tech for more help thee.
Apr 07, 2009 | Frigidaire GLWS1233A Top Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Dec 20, 2008 | Washing Machines
Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Oct 15, 2007 | Washing Machines
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
