Question about Hitachi CP-X251 LCD Projector
Hitachi projector cp x251 sync is out of range error message
Does not power on
Posted on Sep 23, 2010
Projector does not recognize computer
Hi Becki.
Projectors will usually be identified on your computer as additional or optional screens/monitors. Depending on your setup (laptop/desktop) you may have some alt keyboard buttons with icons for single/multi screens. You will also likely have monitor control panels or non-windows equivalents. In Windows, for instance, right-clicking the desktop will usually bring up a monitor properties page. There you may be able to then select if the projector is a mirror of your desktop, an extension, projector only, or computer only.
if the computer says it sees the monitor, then you'll likely need to toggle whatever sort of menus the projector has to select the input port. Looking through the manual (
http://www.hitachi-america.us/supportingdocs/forhome/DisplayTechnologiesGroup/lcdprojectors/SupportingDocuments/cp-x251_um.pdf ) , suffice to say that there are multiple ways to connect and, with that, plenty of ways to have your cable be hooked up and ignored nonetheless.
Hoping this helps!
D
Nov 30, 2015 | Hitachi CP-X251 LCD Projector
It says to Check the air flow
Open the cover. At some ends there will be 'filters', to clean the air entering the projector. If these filters are blocked with dust or lint, air flow will be blocked.
Clean any dust from these filters. Close the cover and check whether your problem is solved.
Sep 14, 2011 | Hitachi CP-X251 LCD Projector
When I turn on the CP-X251, the fan cycles several times and then the overheat light illuminates. Only takes about ten seconds...
have you checked the filter. is there any blockage to air flow. is the machine mounted upside down
Mar 03, 2011 | Hitachi CP-X251 LCD Projector
My hitachi cp-x251 multimedia lcd projector wont power on? the lights wont turn on or the fan nothing as if it is unplugged. please help.
This projector was sold with a 3-year manufacturers warranty. You can contact Hitachi warranty service at 1-800-HITACHI.
If you have a continuing issue or support problems, contact me directly at fkemmer@vsci.com.
Sep 29, 2010 | Hitachi Cpx2510 Projector Cpx2510 Xga...
The image from my cp x251 is uneven the top and right side are angled but the bottom and left side are straight and perfect on the screen.
this is a common problem with projection systems this is the reason that most screens are lined with black felt its non-reflective and works great to hide uneven edges also try balancing out the difference with the keystone adjustment
HitachiTech
Feb 08, 2010 | Hitachi CP-X251 LCD Projector
Hitachi cp-x251 lcd projector cannot adjust the tint.
reset the settings to factory default. make sure that if you are using the computer that you are on vga, not composite. if it doesn't get any better, check the lamp for bulges, black spots, or fogging; replace if necessary. if all that is ok, you may have fried polarizer filters on one or more of the lcd panels due to excessive dust and heat. if that is the case, you'll need to replace the entire optical engine.
Dec 09, 2009 | Hitachi Office Equipment & Supplies
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Need leveling mounts or legs for lcd projector
Best solution I found is going to a hardware store with your broken legs and buying a nice pair of carriage bolts with the same screw pattern. They don't break and work much better then the original legs. I stuck rubber feet to the bottom of the ones I got and am seriously considering going around and replacing the stock legs with these as a preventative measure.
Aug 08, 2009 | Hitachi CP-X251 LCD Projector
Problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Mar 16, 2009 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP-X251 LCD Projector Logo
567 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
