Question about Maytag Dryers
My brand new dryer, about 1 month old, does not have any heat when it is on? Starts and tumbles the clothes but just no heat so the clothes dont dry>
  • 454 Answers
If brand new, just call service.
Posted on Oct 07, 2009
I have no heat when tumbling clothes
While tumbling clothes; how you can heat up?
Dec 07, 2015 | Dryers
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
My washer has been difficult to maintain balance when spin cycle is running for about a month. Also, the dryer has not been spining the clothes as dry as it usually did. Tonight, I put a load in and the...
You did not say what model washer you have. Top Load, Front Load and Model Number... That is very important.
As for the dryer..... If the washer is not getting a decent amount of water out of the clothes then the dryer could be becoming damaged continuing to use it. A dryer simply evaporates the water on tumbled clothes in it. It is is set on a TIME DRY setting, I doubt it will work at all. If it is set on AUTO DRY then, it could be running and running and destroying your dryer. You also may have a heating element that is weak or intermitently going on and off.
It is important to know how old, the brand, the model numbers of everything. Also if it is a Gas Dryer or Electric.
Sorry for the extra questions, but it is neccessary.
Kindly,
Jim
Dec 21, 2009 | Maytag Washing Machines
My tumble dryer doesn't dry the clothes
Check your breaker - a dryer will spin at 120 volts but needs the full 240 volts to dry. If that's not it, check your vent going outside the house and the hose coming from dryer. If its clogged, that's your problem. If not, you'll have a heating element issue which involves two separate fuses (and the element). Its best to hire someone if it gets to that point. Good luck...
Nov 16, 2009 | Dryers
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Nov 01, 2008 | Dryers
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
