Question about Garden
Yard Machines by MTD..Riding lawnmower starter draws energy from battery but doesn't turn. Never replaced a starter. Don't know for sure where it is and what's involved.
  • Chuck
    Chuck May 11, 2010
    Where it is and what is involved depends upon what engine brand, model and type or spec number. Since you don't have any of these listed, it would be difficult if not impossible to offer you any advice
  • 472 Answers
ITS NOT HARD UN HOOK THE BATT CABLE THEN RE MOVE THE CABEL FROM THE STARTER REMOVE THE 2 BOLTS THAT HOLD IT ON PUT THE NEW ONE ON HOOK UP THE CABELS AND TRY IT LET ME KNOW IF THIS HELPS
Posted on Oct 07, 2009
I WASHED THE TOP OF MY LAWNMOWER DECK ON MY MTD YARD MACHINES AND NOW IT NO LONGER WILL PULL WHEN IN GEAR FORWARD OR REVERSE
It sounds like maybe your belts are wet and slipping. Try it tomorrow when its dry and see what happens, if there is still a problem, let me know.
Aug 02, 2013 | Mtd Garden
Lawnmower cannot pull starter recoil
You can take the recoil unit out and replace it, you may also be able to recoil save that one if nothing has been broken
May 05, 2012 | Mtd Yard Machines 158cc Briggs and...
Ground wire from key switch starts burning when i try to start riding lawnmower BATTERY GROUNDED GOOD
You have a ground issues somewhere of where a wire may have rubbed the frame and is shorting out, wrong solenoid (frame ground verse wire ground) or a starter issue.
Take the starter off and test it with a good battery and jumpers to make sure its working correctly. Second...start tracing your wires back to the solenoid and then to the switch looking for bare or loose wiress.
www.nnyparts.com
May 30, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
I do not get any speed from my riding lawnmower
An MTD riding mower is belt driven. Usually 2 belts on a variable pulley ( excepting hydrostatic drives). Replace both belts.
Jan 02, 2010 | Mtd Products Yard Machines 158CC Tiller
Have MTd 42'riding lawnmower. It was running well, I turned it off the machine, took break and now it just clicks at the solenoid. I have replaced solenoid, battery, and now it still clicks. What do you...
Try jumping directly to the starter. If it still won't turn, try placing your hands flat on the screen and turn it back and forth sharply to try to dislodge the starter gear from the flywheel. They can, on rare occasion, get wedged in the flywheel and not turn. If none of the above work, I'd remove the starter and bench test it.
Jun 14, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have changed the starter, solenoid and battery it ran fine last year now I can't get it to do anything. I checked the battery and the charge is fine. The fuse is ok also I changed it to make sure. Last...
Can't get it to do anything is not a very precise description of what the problem is so I will take a guess and say that the problem is that when you turn the key there is no click and no attempt by the starter to begin spinning. This would tend to indicate a problem like a wire that came loose or a bad key switch. You have done a lot of work on it so re-check your work and make sure it was all done correctly (after 30 years I still make mistakes. NOBODY is perfect).
Apr 30, 2009 | Mtd Products Yard Machines 158CC Tiller
I have a MTD Yard Machines riding lawnmower that keeps blowing the fuse from the ignition to the starter. What could be the problem? The ignition switch itself or maybe a bad wire?
One problem that i can think of off the top of my head is that the magnets under the flywheel are in direct contact with the stator under the flywheel, which if that be the case, both would need to be replaced
Apr 20, 2009 | Mtd Garden
Garden Logo
272 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
