Question about Husqvarna Viking 1
When I step on one side of my foot pedal the machine works, but pressure on the other side does not turn the machine on.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
That foot pedal had a feature of High speed on one side of the pedal and low speed on the other. Either your speed control unit inside the pedal is slightly burnt or the spring inside the pedal has moved out of position slightly. Even dirt could be the culprit if it found it's way into the speed control unit inside the pedal.
Posted on Oct 08, 2009
How do I fix my singer 6333? I plugged it in the light comes on the foot pedal is attached but no air coming the machine to the foot pedal therefore no sewing action how do I fix it?
There are some sewing machines that the foot pedal is driven by air pressure. Sometimes they will develop leaks so the air does not build up enough pressure to activate the machine. You might see about finding a replacement foot pedal--however if that is not the problem, you may waste your money. Perhaps a sewing repair shop can help you.
Oct 28, 2015 | Singer Sewing Machines
When stepping on pedal, my juki 5550 straight sewing machine, why will the machine not run? Light works but not machine
there could be something wrong with the foot pedal, it may need to be serviced or replaced, or there could be something wrong with the plug where the foot pedal plugs into
Feb 20, 2015 | Juki DDL-5550 Industrial Straight Stitch...
My air elecntronic SU, which is thirty years old, doesn't always stop sewing when I take my foot off the air pedal. The machine keeps running until I tap a number of times on the pedal or turn the machine...
This will be the bellows inside the side panel of the machine where your foot pedal air line feeds into rather than the foot pedal. Really short of cutting or sitting on the air line with your chair, not much goes wrong there. It,should be repairable if you can locate a Swiss Elna trained/experienced techician.
Jul 01, 2014 | Elna Sewing Machines
Foot lock does not lock so machine won't turn on
unplug the machine & look at the foot pedal. any dust,etc around the edges can keep the switch from making. open the foot pedal (probably has 4 screws) find the little switch, it probably just needs to be cleaned. if it still wont work search for a new one using the numbers on the side of the switch.
Mar 31, 2014 | Sewing Machines
Pedal not working
the least expensive option would be to try a used the foot pedal
Feb 05, 2014 | Bernina Sewing Machines
Serger repairMy Viking 910's motor has decided to sound like it's still running when I've taken my foot off the foot pedal. (It sounds as if you are applying the lightest of pressure) I have taken the...
When this happens unplug the foot pedal and see if it stops. That would suggest it is in the pedal. Does the machine try to turn when this happens?
Jan 31, 2014 | Husqvarna Viking 1
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
I have a Husqvarna Viking 2000 SL and it seems there is a short in the cord. The machine has power because the light turns on, but the foot pedal does not work. Any suggestions?
The first thing to check is the pedal itself. If you have a continuity tester you can check to see if a connection is being made in the pedal when it's being stepped on.
You can also turn the handwheel back and forth while you step on the pedal with the power to the machine on. If the motor starts to run a little bit, you know the pedal is good and the motor carbons will be bad.
That machine's rear cover over the motor comes off somewhat easily, so you could also check the connections in the electric terminal where the foot control plugs in. Make sure to have it unplugged when you do this part. Gently move the wires near where they connect to the terminal block and see if any are loose. There are screws there that tighten onto the wires that sometimes loosen which would make your pedal not work.
Oct 07, 2009 | Husqvarna Viking 1
Bobbing Winding
i have and love this machine...pull out the large side knob on the right side of machine and switch the bobbin to the right side on the metal winder at the top.you will hear a little pop on those 2 steps...put a thread thru the hole in your bobbin and give your foot pedal some pressure....really easy
sonyainkaty@sbcglobal.net
Jun 02, 2007 | New Home HF-2022
Sewing Machines Logo
200 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
