Question about Whirlpool GEW9878LW Electric Dryer
Have a whirlpool gb awz2303 heats ok but drum would'nt turn turned drum around went ok for about a month then same thing happend do you think its the belt streched
  • 87 Answers
By what your saying, yes the drum belt is stretched and or is sliding out of track. You can check this by removing the back panel, be sure to shut or unplug power first, then you will be able to see what i am talking about. hope this helps
Posted on Oct 07, 2009
  • Tony Hughes
    Tony Hughes Oct 13, 2013
    Hi I have an whirlpool awz2303 drier where the belt has snapped, got the belt taken it all apart cleaned it up all ready. Now I am looking at the jockey pulleys like garbage, all the instructables I have seen have single tension pulleys, this has two in a V with a spring in the middle, the belt obviously does not thread through it. Does it just sit with the belt kinda clamped between the pulleys like a clothes peg? I can\'t find anything on the web to describe it.
The drum is not turning, where is the belt?
depends on the dryer model.
whirlpool kenmore and others from White industries is wrapped around the drum. U must open it up from the top and front.
Maytag and others r around a pully and I think r accessed from the rear. may as well buy a front seal and high temp adheasive for the drum belt style. It will probably need it.
Sep 21, 2014 | Dryers
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
My whirlpool AWZ2303 only seems to be blowing cold
If your not getting heat from the machine its probably due to a faulty heating element. You can get the part at an appliance parts shop by bringing them the model number or you can call in a pro repairman to have a look and replace it. Do it yourself is cheaper by far but can be difficult on newer machines like this one.
Dec 11, 2009 | Whirlpool Dryers
Thermal Fuse keep failing
Fuse and element failure is related to lack of air passing over the element. The drum and fan should run even if the heater is inoperative. Find out what is stopping them, then work on heat. If motor is running, there should be air flow--pull vent hose from wall outlet--should be brisk air flow. If not, remove the lint screen and check again. If now ok, soak the lint screen in hot water and detergent. If drum does not turn, check the drive belt and if it sits properly on motor pulley.
Aug 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Duet Sport Dryer drum will not turn
Most likely thermal fuse is bad, but also could be door switch or a control problem.
Oct 12, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Thin Twin Model LT7000XUNO stack unit
ithink I have the lt7000xuno
something got jamed in it now the drum won't turn mabe spun abelt or is there a cut off switch?
Aug 05, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool dryer LEC8858EQ2
one of 2 things, over temp protection activating due to insufficient ventillation or motor is defective and heating up excessively.normally if both drum support wheels are worn or defective,plus if veld strip on drum is worn, motor will overwork and fail.
Nov 15, 2007 | Whirlpool LER5636P Electric Dryer
Whirlpool GEW9878LW Electric Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
