Question about Blitzz Technology (BWA611) Router
I want to secure the lan and I don't have the directions anymore
  • 4,281 Answers
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi security *** your WEP code it is your security key to connect wi fi network.
Change it and then save settings and restart router.
Let me know if you need more assistance.
Thanks
Posted on Oct 07, 2009
  • Install anivirus in all LAN computer.
    Also enable firewall in router.
    Only open port http 80 , ftp 21 ,telnet 23 in router block other ports .
    Then save and restart router.
    Thanks
  • Sir please change your rate.
    Thanks
Firmware upgrade failed
Try Factory reset, and try to access the router from web browser and you will get direct option to upgrade.
Mar 09, 2014 | Draytek Vigor 2130 Gigabit LAN / WAN...
SAMSUNG SMO-211QN SECURITY SYSTEM
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
http://www.retrevo.com/s/SAMSUNG+SMO-211QN+users+manual+?sub.x=75&sub.y=14
Dec 07, 2007 | Samsung Color Indoor Security Camera with...
I hit the RESET button on my router and now the INTERNET provider says I need to find my maual to re install it. I do not have a manual anymore....
Can you give more information about your internet provider?
Router does not need any information as long as you have an active internet connection. You may have to check connecting your computer first directly to the modem provided by your internet provider. Once you confirm that you have active internet connection disconnect cable from your computer and connect to WAN port on Linksys router. Power on your linksys router. Now you can check connecting your computer to one of the LAN ports on linksys router. you should be on!
The next step would be setting router for security! good luck!
Sep 03, 2011 | Linksys Wireless-G WRT54G Router
On my GPS, I have come across several "non
The points of interest can not be changed on the map data.
Changes to the points of interest can be submitted to Navteq.
http://mapreporter.navteq.com/dur-web-external/secured/submitDur.do?userType=CONSUMER&language=en
Aug 23, 2011 | Garmin Nuvi 760 Car GPS Receiver
It went off line and I can not get it back, I may have messed up the security key but don't know how to change it
Hi, you can start working your router again by resetting the configuratio, try to do this,
1. Power on your router, and at the back of it there is small hole, pinch it by the tip of a ballpen or any small object that can get through it. press it for 3-4 seconds and you will see the the LEDS will lits off then start.
2, Reset the power and connect via wired connection in your router LAN port to your laptop LAN port also..
3. at your internet explorer URL type http://192.168.0 1 to access your router IP address and configuration. Once inside window will pop up asking your username and password, for username just encode admin and no password.
4. Go wizard configuration to configure your wired LAN with the given credentials from your service provider, save it then proceed to wireless configuration and select the connectivity your want and have it secure with security access password for authorized user and save it.
Jun 21, 2011 | D-Link DIR-615 Wireless Router
Lan driver download link
SInce you don't clarify your op. system, I suggest you to follow this link, choose your op. system and download the requested drivers.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 04, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
How can i input a security wep key
First you have to connected to it. You can do it wireless if you already configure your ssid and key or directly using a Lan cable. Some routers connect you directly using the CD ROM provide with it or using your internet browser but you need the IP address of the router that normally is show in the manual or in the same router. After you connect to the router you should look for the security configuration and configure your security web key.
Something like this: gabytek_0.gif
Mar 03, 2011 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Wireless security enabled and lan not able to work together
Try to set up an IP reservation for your ethernet using the MAC address of your NIC, this way the router can't steal it for the WLAN.
Mkae sure that if the router is run as a DHCP server that there are suffcient on IP address range to allow extra PC's to be leased an IP address.
I suggest that you disable in WZCSVC on both your wired PC and wireless PC and use the laptops own NIC connection software and the routers WEP or WPA-PSK to allow you to connect your wireless
Dec 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
Security
the router is web enabled, it contains a setup system.
from a lan cable connection, you dont want to lock down wireless from wireless, and lock yourself out if you make an error
http://192.168.0.1
and follow the setup wizards. the helpscreens are useful to expplain what & why you are doing.
Jul 13, 2008 | D-Link Xtreme N DIR-655 Wireless Router
Blitzz Technology (BWA611) Router Logo
119 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
Will Halftowaite
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
