Question about Dryers
Whirlpool Dryer Purchased 3/2007. \r\nModel # GEW9250PW1 Serial # MU01022179 1st issue was the control panel was very dim and wouldn't let you change settings or turn on the dryer. Checked with volt and couldn't find loss of voltage anywhere and even though the electronic control board on the top of the tub had 120 volts we replaced it anyway thinking that may be the problem. Replaced temp sensor on the bottom and the moisture sensor due to poor drying in the past few weeks. We have checked the outlet and have 220 volts and replaced the cord with a new one. It worked 1 time and once it completed the cycle it wouldn't start again. Now the panel is dim and will not let you choose an option or start the dryer. Has anyone else experienced this issue and what is the fix? We have already dumped $250 in a 2 yr old highend dryer and VERY disappointed. Thank You Neil Noe
I have a whirlpool duet dryer GEW9250PW1 and the control panel wont come on, I have took out the circuit boards cleaned them with contact cleaner blew out the top and took off the bottom panel and blew it out, after all that it still wont come on unless you unplug it for at least 20 minutes.
Posted on Jul 18, 2010
How to reset whirlpool duet dryer model WED9200SQ0
Hello, sorry that you are experiencing a problem. To reset the Dryer we would recommend unplugging the unit of turning off the breaker for 2-3 minutes. If this does not correct the issue we would recommend having a certified technician out to correctly diagnose the issue. If you would like further assistance you can send us your name, address, phone number, model/serial number and the date of which you purchased the appliance to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 18, 2017 | Whirlpool Washing Machines
Control locked light is on? whirlpool duet dryer-mod GEW9250PW1.
Hi
Press and Hold the End of Cycle Signal button for 15 seconds, this will unlock the control. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Whirlpool GEW9250P Electric Dryer
I haven't used my dryer in 3 days and when i went to use it today it wouldn't come on when you pressed the button. The light is on in the dryer but nothing to the control panel. is it going to be a...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 29, 2011 | Whirlpool GEW9250P Electric Dryer
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
What does F-1 mean on a Duet front load dryer? Our dryer's lights will turn on but, the dryer will not start up. At first we thought the control panel was locked out. But, it wasn't.
The "F-1" error code means a failure occurred with the electronic controls.. This could mean that wires are broken, the electronics shorted out or a manufacturer's default error shut the washer down.
Prevention/Solution: The electronic control panel needs replacement. Find your dryer serial number and search for the part online. This is a lengthy job that usually requires a repairman unless you have dealt with and repaired dryers before.
If your dryer was purchased within the past couple of years, the dryer could be covered under the warranty. Visit the Whirlpool customer service page for more information or Whirlpool-Duet-Dryer-fault-codes
Hope this helps.
Jun 02, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 06, 2010 | Whirlpool Dryers
The controls will not come on when I press the power button
if you tapped on it and it work then you have a loose connection somewhere
Aug 27, 2009 | Whirlpool GEW9250 Electric Dryer
Un able to unlock control
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
May 24, 2009 | Whirlpool GEW9250 Electric Dryer
DIM LIGHTS ON CONTOL PANEL
I had the same problem dim lights nothing happens when buttons pushed. I went through the trouble sheet that was in the drying and it pointed me to a bad control board. After replacing the control board it work. Awsome huh. Not it did the same thing a few hours later. I was able to unplug and replug and it worked for a bit and stopped again well after a few times of that it stopped all together. I was kinda upset after spending 135 bucks on that. I didnt want to put any more money into this machine. I took the machine apart and checked all the connections and wires. Removed the front panel and took all the ribbon cables off and made sure those were good too, (didnt short out) everthing checked out. For grins i replaced the 30 amp circuit breaker. The voltage was there but maybe its not getting the amps. I put the drying togeter enough to see what it dose. I didnt want to risk the chance of messing up the control board i bought while doing this so i used the OLD ONe. ( board was sitting on the dryer tub not bolted down). Well low and behold it works. I have been testing it for about 3 hours now. turning it off and on. change the setings on the dryer and so far it is still working. Before it would have messed up already.
Jun 30, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
297 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
