Question about HP Compaq nc6000 Notebook
Compaq nc6000 powers/boots up and then off.
Compaq nc6000 powers boots up and then off. There are no lights and the screen does not appear. I can hear the fan blowing during power boot.
  • 1 more comment
  • medwards_ran Oct 07, 2009
    safe mode did not work, same action occurred
  • medwards_ran Oct 08, 2009
    My compaq nc 6000 was working fine but shut off. Since then whenever its turned on the motor starts, the fan blows but after about 15 seconds it turns off again. Also, there are no lights and the screen never shows.
    Thank you, I'll get an OS disc and try!
    President:
  • 2,600 Answers
Lets start with this....This may or not work depending on if the screen comes up. You may have to try and connect the laptop to an external monitor for the repair, Understand that most of these types of problems are usually indicative of a bad motherboard. Get back with me and I'll try to help further.
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 09, 2009
    President:
  • 1,865 Answers
Reseat the RAM, restart the computer with the OS disc in the dvd/cd-Rom player.
Posted on Oct 08, 2009
    President:
  • 1,922 Answers
Try and boot-up in "safe- mode" by pressing f8/f10/f12 depending your type of system and do this before h.p. logo disappears or you'll miss going into safe mode then you can trouble shoot in safe mode
Posted on Oct 07, 2009
  • daniel  hendrickson
    daniel hendrickson Oct 07, 2009
    screen is totally or do you see the blank," blue screen" of death?
Power up but sreen wont come on
Try connecting an external monitor to the blue D shaped plug on your laptop. If you boot up and the screen appears on the external display., you have a failed backlight or cable on you laptop screen.
Jan 26, 2014 | HP Compaq nc6000 Notebook
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
My hp nc6000 laptop wont boot up i need to reset it to factory setting
When you power on your laptop immediatly after powering on your laptop start pressing F8 key on your laptop keypad, after few seconds Advance boot options menu will appear in front of you in that menu select (repair my computer) option will take you to unother sub menu which will give you an option of load factory image.
Sep 02, 2011 | HEWLETT-PACKARD Hewlett Packard Compaq...
I have a Compaq nc6000 that would not boot up. I
Sounds like your display panel is bad or it's another symptom of a mother board flex problem at the Maxim chip
May 22, 2010 | HP Compaq nc6000 Notebook
NC6000 starts to boot but then turns off, no lights or screen. I can hear the fan when the power is turned on?
On ac adapter and battery power,could be several things sounds like bad caps on the main board. Less expensive to replace the motherboard.
try here
www.ebay.com
Oct 07, 2009 | HP Compaq nc6000 Notebook
No boot Device Selected error!Compaq!
Sorry, sounds like a dead hard drive. If you can gain access to the drive, you should check for loose connections. Also, listen closely to the notebook as soon as you start it up - can you hear the drive spinning? Can you hear any loud clicking or grinding noises? Any odd sounds can also mean a dead or dying hard drive.
Good luck, and please rate this answer if you feel it has helped you!!
May 11, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 won't come on
well make sure the battery is fully charged you could have a bad motherboard or no memeory inside it check those first
Nov 08, 2008 | HP Compaq nc6000 Notebook
Screen will not power on
try pluggin an external monitor to the laptop. If you see the screen then your filament ribbon might need repair or replace.
May 06, 2008 | HP Compaq nc6000 Notebook
hai
check the smps it may be the problem or check your moniter by removing the data cable from the cpu for the OSD display
also check the ram
Apr 24, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
153 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
