Koakes898, Here is a clue!! Have you seen the new style Curlie-Q compact fluorescent (CFL) screw-in light bulbs at the nearby Home Depot or Menards. Can you imagine them having long, thin, straight tubes and providing WHITE LIGHT on the opposite side of the screen of your FPD2275 display. If the "switch-mode-power-supply" detects a Fault in the cold-cathode-fluorescent-lamp" "electronic ballast" circuit Called an "INVERTER" it goes into SHUTDOWN mode to try and save itself from self destruction. Visit YOUTUBE and search out video clips (8-12 min run time) on "LCD disassembly" FYI !! I'll bet your monitor is in the top 2 types of power supply failure modes. Then you will Probably be able to decide on what to do with your monitor. Trade in for new, or BUY new and repair old to keep as spare. or try to do cash+ old swapout with Gateway for a same model-Refurbished. You do have a few options. Last option is attempt repair on your own if handy with soldering pencil and solderwick and solder. Lots of stuf on the web, you just need to do the search!! I'mlouie12fix on fixya. or lmistyrel @aol .com Hope this was helpful in some way. please rate this on fixya if this was of some use to you. Bye for now.
SOURCE: monitor screen blank and LED orange light flashing
For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
