Question about Ricoh Aficio MP1600SPF Copier
We have a Ricoh aficio 2051sp with error code SC555 what does this mean?
  • 541 Answers
You will need to remove these and test with a multimeter. we are in michigan do you need a ricoh copier service 248-677-8112
Posted on Oct 11, 2009
    Problem Solver:
  • 10 Answers
Fusing lamp error. 1 thermistor bad or out of position.2 bad thermofuse
3 fusing lamp bad
Posted on Oct 07, 2009
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
RICOH AFICIO 5500 - SC555 ERROR HOW CAN THIS BE CLEARED?
press yellow clear then enter 107 and press and hold the orange stop key untill you enter service mode.
select copy sp
press 7807 and then the # key. select execute on the righ on the display
when it says complete turn off the machine from the red power switch. turn machine back on. if error returns repost here .. you may need parts
Aug 08, 2011 | Ricoh Aficio 1224C Black and White Copier
Service Code Error SC555. This machine is not connected to the network. There is not an obvious paper jam. Can you describe a possible fix. Carolann
SC 555 is the main motor error. the main motor needs replacing. its the only solution. the main motor fits at the back of the machine. if you open the back cover, you will be able to see it.
Nov 19, 2010 | Ricoh Aficio MP1600SPF Copier
Mp6001 with sc555 error code
Fusing lamp overheat error (rear)
555 A
After the fusing
temperature reaches the
target temperature, the
fusing lamp does not turn
off for 20 consecutive
seconds.
?? Fusing thermistor defective or out of
position
?? Power supply board defective
u need a servise engineer to reset/fix it
Nov 18, 2010 | Ricoh Aficio MP1600SPF Copier
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
Ricoh 2051SP error code J013 & SC495
SC495 is a toner recycling system error, due to strain on the system. Most likely due to a blockage. system needs to be removed and thoroughly cleaned. J013, is simply a jam, and this would be happening because of the toner recycling system being locked up, and seizing the motor. You DEFINITELY need a tech for this.
Jul 16, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio MP 6000 copier with error code SC555
there is no sc 555 on those machines only sc 550 and that relates to what is called a fuser web.It does need to be changed but you can reset it by pressing the following in order
1- yellow clear key
2- number 1
3- number 0
4- number 7
5- press and hold down the orange clear/stop key for 5-10 seconds.
the screen changes
select copy sp
select sp 1
scroll down to SP1902 001 and select
reset that value to 0 and select enter
switch machine off and on and that should get you going for now.
Let me know
May 23, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh 3800c Error code sc555
SC 555 Pressure roller
fusing lamp
When the fusing unit is not
running in the Ready condition,
the pressure roller fusing lamp
keeps ON with full power for
100 consecutive seconds.
Replace the fusing unit.
Dec 01, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh 3800c error code SC555
fuser related -- call tech to reset --- thermistors
Ricoh Aficio MP1600SPF Copier Logo
500 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
