Question about Epson Stylus NX400 InkJet Printer
Photos have bars across and color is bad - Epson Stylus NX400 InkJet Printer
  • 21 Answers
Replace the color print cartridge(s). If you have already done this, the new cartridge(s) could be bad. This is especially true of refilled cartridges. On average, I find 25% of refilled cartridges are bad as soon as I plug them in. For that reason, I no longer use refilled cartridges unless I do it myself.
If you are sure the cartridges are good, then run the printer's cleaning and alignment utilities to see if that corrects it.
Posted on Oct 07, 2009
3 Suggested Answers
  • 13433 Answers
SOURCE: Problems printing photos
Are you using HP cartridges with the printer? there are known problems with non hp cartridges in hp printers.
Posted on Jul 21, 2008
  • 81 Answers
please specify what printer, model,
Posted on Jul 23, 2008
Samsung TV display has gone out - has audio, but there are vertical, colored lines/bars across entire display.
Call a television engineer. Don't try and fix it yourself it always ends badly and more expensive. Could be a board, a component on a board, a bad connection, or blown capacitors. The course is 2 years full time education.
Apr 30, 2018 | Samsung Televison & Video
Jul 21, 2008 | Apple HP Officejet G85xi InkJet Printer
Small bars across picture with no color
I have exactly the same problem and a Dell tech just recommended I replace the drum cartridge - $170.
Nov 07, 2009 | Dell 3000cn Laser Printer
I was getting streaking across all photos that I was scanning. So bad that I researched getting a new scanner. Then one day it started working just fine. Now today I scanned some slides and when I tried to...
sounds like the scanner is skipping pixels. that is usually a sign of malfuncting. the best solution is get a new one. cost of getting new one is much cheaper to repair it.
Oct 17, 2009 | Canon CanoScan 4400f MultiFunction Color...
Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
May 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Sometimes after the my TV is one for 20 mins or so the screen warps, shooting white/pink/green lights across the top and bottom of the screen and placing a horizontal black line at the bottom like hal
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 19, 2009 | Hitachi 50FX20B 50" Rear Projection...
Hitachi 46F500 and there is a blue curved bar
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Hitachi 46F500 46" Rear Projection...
Jul 23, 2008 | Apple HP Officejet G85xi InkJet Printer
White bar coming across my k800i's screen.
try changing the current theme of your phone and check if the white bar will still appear...
May 03, 2008 | Sony Ericsson K800i Cellular Phone
Epson Stylus NX400 InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
