Question about Fossil CH2331 Wrist Watch
Wrist band adjustment on a fossil watch
I need to know how to adjust the band to fit my arm
  • vnvalleyboy Jan 07, 2008
    i don't know how to adjust the metal band on my fossil fs 4236. the solution offered for fossil2331 isn't clear to me. i don't understand what the tool is he is talking about
Just take a tiny little jewelery screw driver small enough to fit in the pin hole and tap it with anything that you can find. Then pull out other end. Look for arrows indicating which way to remove pin and go in that direction Some pins are like a hairpin and have a split at one end. Replace solid end first opposite of arrow direction. If there are arrows in both directions on the same link; like Fossil for instance, that means that it doesn't matter which direction the pins are removed or replaced. They are solid and they can go back either end first. It's easy. To get the pin in all the way I just used the little screw driver and tapped it in. Good luck.
Posted on Apr 30, 2009
  • jp12steps May 06, 2012
    Thanks for a straight forward answer!!!!!
    Problem Solver:
  • 6 Answers
The tools to do this are expensive unless you do it all the time. You can go to your Fossil Store and they will adjust your watch quickly.
If you do not have a Fossil store near you, go to a jewlery store or jewelry repair shop and they will do it for anywhere around $2.00 to $14.95.
The Fossil Store does it for free, though!
Posted on May 15, 2009
    Guru:
  • 1,894 Answers
U can do it yourself using a cutting player and a small sharp apparatus..
just detach the watch and the band using the sharp needle like apparatus..
now you can remove off the unwanted portion by pulling off using the cutting player,...
Posted on Dec 24, 2007
    Problem Solver:
  • 13 Answers
I just adjusted my Fossil watch by using a small pick tool, it had an end that was small enough to fit into the hole on the end of each link. You just have to push hard sometimes to force the pin out at the other end. It helps to push against something that will give a little or to hold it sideways as you push to see when the other end will begin to poke out, then use a pair of tweezers to pull the rest of the way out (the pins are very narrow).
Posted on Apr 06, 2011
What is a cutting player
Posted on Jun 03, 2008
SOURCE:
I need wrist band for fossil model # JR8190
Just go into your local jeweller. They have a huge selection and will fit it for you.
Jun 06, 2012 | Fossil JR8190 Wrist Watch
Can the band on my Ed Hardy watch be adjusted? It is much too large. Do you think a jeweler can make the band smaller? There is some kind of clip on the underside of the watch band.
yes, it can be adjusted. just bring it to watch expert and surely they know what to do. any watch are made are adjustable to fit in customer's wrists.
Jul 18, 2011 | Watches
Fossil watch pink es2206 need more links, band too short
You can get links from Fossil.
Go to "fossil.com" and scroll down to the bottom of the page. Click on "customer care" and under "product info" you will see "ordering links and bands".
Click on this.
If you are not sure how to fit the new links and they do not send you any instructions, take your watch to a watch shop who will fit them for you.
Feb 17, 2010 | Fossil ES9382 Wrist Watch
How do I adjust my watch band?
If you want to deuce the size of your band then I have found some instructions on the Fossil website and since most watches are very similar you can try the method described there.
If you need to replace links then you can get them for Skagen (free!).
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions"
Feb 14, 2010 | Skagen 355LGSC Wrist Watch
HEY GUYS WHERE CAN I BUY THAT WATCH BAND ADJUSTMENT TOOL
You can buy it on eBay. Choose JEWELLERY AND WATCHES, then click on TOOLS. There are plenty of watch band adjustment tools.
Rate me, please.
Aug 06, 2009 | Fossil CH2331 Wrist Watch
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Fossil watch band adjustment
throw the ******* thing away
Dec 26, 2007 | Fossil AM3695 Wrist Watch
Watch band
How can I remove a link from my watch band to fiit my wrist?
Dec 22, 2007 | Fossil AM 3688 Wrist Watch
How to adjust band
My best suggestion to you is to take it to a Fossil store (they will do it for free!), or go to a jewelry or department store (Dillards, Foleys) to get it sized right.
The problem with doing it yourself is if you do not have the correct tools you can scratch the watch or bend the pins easilly. Especially with the black band like you have.
If you go to a jewelry repair shop they will charge you. I have seen them charge anywhere from $2.00 to $15.00. Unlike Fossil or a few other big department stores.
Dec 12, 2007 | Fossil AU4003 Wristwatch
Band adjustment
Use a pick tool and push the pins out the sides in either direction of the arrows.
Nov 17, 2007 | Fossil CH2331 Wrist Watch
Fossil CH2331 Wrist Watch Logo
7,573 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Ray Murphy
Are you a Fossil Watch Expert? Answer questions, earn points and help others
