Question about Cameras
Camera want zoom in and out - Cameras
Just purchased it from bid tv it has 4xdigital zoom would i have been better to get optical zoom instead this is my first camera
Digital zoom enlarges the ccd image and will become more pixelated the more you zoom and optical zoom uses an actual lens to magnify the image coming into the camera. optical zoom is better than digital zoom.
Sep 25, 2009 | Vivitar 7.0MP Camera Digital Camera with...
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Zoom
have you tried to check the mode or settings? Digital zoom is different from manual or analog zoom, when we say digital zoom the camera expand the picture digitally, the zoom lens is not moving when it reach its maximum length but the picture keeps on zooming in.
Sep 29, 2007 | Canon PowerShot A95 Digital Camera
Digital zoom not working
Digital zoom is in the menu and must be turned on to activate it. When you use the zoom it takes 2 opperations to function. First opperation is to zoom all the way in then the camera should stop. This is the limit of the optical zoom. Then you let off the zoom button, and hit it again and then the digital zoom will start. Digital zoom is just a gimic if you learn how it works its not doing anything different then you can do in photoshop. All digital zoom is doing is like cropping.
Apr 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Zoom function
Yes. This camera has 3x optical zoom and 4x digital zoom. However digital zoom cannot be used in 2880 x 2160 size. Optical zoom: It is approximately 5.6 - 16.8 mm. (equivalent to 38 - 108 mm on 35mm film camera) Digital zoom: It extends to 4x from telephoto end (108mm) of optical zoom.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
Super Zoom
In addition to the optical zoom, this camera is equipped with a super zoom and digital zoom for taking telephoto and wide-angle shots. The super zoom and digital zoom cannot be used at the same time. Super zoom is used to extend the optical zoom up to 14× magnification. However, the resolution is automatically fixed at 1600 ×1200. Digital Zoom is used to extend the maximum optical zoom to approximately 40x. However, pictures taken with the digital zoom may appear grainy. Camera shake is likely to occur at these higher magnifications, please see “camera shake” question for further details on this.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Super Zoom
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Telephoto zoom
The D-575 Zoom has a 3x digital zoom and a 3.3x digital zoom, which gives you a total zoom of 10x. Use the shooting mode menu to activate the digital zoom feature. The D-575 camera has a 3.3 digital zoom, which gives you a total of 10x zoom overall. Simply use the Shooting Mode menu to activate the Digital Zoom feature.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Differences between Optical Zoom and Digital Zoom
When you change the focal length of a zoom lens, the subject is magnified. Optical zoom replicates the zoom of a 35mm camera. Digital zoom takes a portion of the image's data and displays it at full size, producing a magnification of the original image, similar to the effect of using a telephoto lens. However, the process is different from the magnification produced using the camera's optical zoom, and the stronger the digital zoom, the more the image will degrade.
Aug 30, 2005 | Panasonic Lumix DMC-F1S / DMC-F1K Digital...
Cameras Logo
12 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
