Question about Lexmark Wheelwriter 1000 Typewriter
Blinking lites on line space - lower right hand side of typewriter - turned machine off and on to reset - lites continue to blink - unable to type
  • Lexmark Master
  • 3,594 Answers
You probably need a keyboard but first try my tip under WW1000.
DickyO
Posted on Oct 12, 2009
The space bar in a Brother GX-6750 typewriter is not working. How can I reset it or get it working again?
You must remove the case, then remove the key board, disassemble and clean it with alcohol .
DickyO
Sep 12, 2015 | Brother GX-6750 Electronic Typewriter
I have an IBm Wheelwriter 5 typrwriter. When I turn it on the line space lights blink and I cannot type or get the casette to move at all.
How many beeps? Which Lights? Blinking together or sequentially? These will help to determine the problem.
DickyO
Aug 04, 2011 | IBM Wheelwriter 6 Typewriter
When I turn typewriter on it blinks 6 times and 2 lights on the line spacing blinks. I've replaced wheel and cartridge; turned on and off - problem remains.
The keyboard is bad. You can try my tip under WW1000 or contact Geo. Beyers Co. @800-392-8085 for a ketboard rebuilt.
DickyO
Jul 12, 2011 | Lexmark Wheelwriter 1000 Typewriter
WHEN TYPING A HALF SPACE IS SKIPPED OCCASIONALLY AND WILL NOT CORRECT THE LETTER TYPED, IS THE LETTER WHEEL REPLACABLE?
To answer your question yes the print wheel can be changed, BUT that is not your problem. The machine needs to be reset or the reset tab needs adjusting.
Background;
When you turn on the machine the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
I would
  1. Power it off and then turn it back on and test to again.
  2. If it's still typing the wrong or unreadable letters then turn off the power open the lid. On the bottom of the case there is a metal frame on the right side of the frame you will see a small metal tab pointing towards the print head.
    1. (When the machine resets its self, it uses that tab as a reference.)
  3. That tab is easily bent which causes the reset to be wrong. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It doesn
Nov 30, 2010 | Brother EM-430 Typewriter
IBM LEXMARK WHEELWRITE 5 TYPEWRITE NOT TYPING
Be sure the print wheel is properly installed and that there is no debris in the P/W area. otherwise you'll need a tech.
DickyO
May 19, 2010 | IBM Wheelwriter 6 Typewriter
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
WW6 will not type.
Check to be sure the printwheel is properly installed and that there isn't any debris in the printwheel area. DickyO
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 15 Series II not working
It sounds like the keyboard is bad. Check the two bflat connectors from the keyboard to the PC board, if they are connected ok a keyboard is in order.
DickyO
D
Dec 30, 2008 | Lexmark Wheelwriter 15 Series II...
How do you replace the batteries on an IBM Wheelwriter 3
Look inside the case (lift the top cover) down in front of the keyboard on the bottom of the machine on the right sid is a black container slide it to the side and you can replace the battery
Dec 15, 2008 | Lexmark Wheelwriter 3 Typewriter
Lights blink and machine beeps
Check the flat connector that goes to the indicator lights the edge of the keyboard sometimes wears into itand causes a reset sequence.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
143 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
