Question about Watts Onan Portable Generator - 4000 , Model# 5500
ONAN 4000, in 94 model class C RV, running good, just stopped, all fuses checked ok, gas to carburetor gas filter clear doesn?t appear to be stopped, gas in bowl of carburetor, there is fire to plug, no evidence of gas to plug though, suspect trash in carburetor. Any trouble shooting ideas on starting point before have to remove carburetor?
Problem solved, Appears fuel pump went bad and only gas in Carb was residue.
Posted on Oct 08, 2009
WE are having carburetor problems with our Cummins Onan RV generator RVQG5500. When we hold the choke down or spray gas into it, it will run, but as soon as we quit doing this it stops
Have you checked for a clogged fuel filter? Does the carburetor have a float? If so, maybe the float needle is getting stuck! Are you using ethanol-laced gasoline ... which can DISSOLVE viton-tipped needle valves?
May 12, 2017 | Electrical Supplies
I have a 6500 lp onan marquis generator in my rv that wont start. any suggestions?
Check the fuel. If old, drain & refill it.
Check for spark.
If the fuel is there and good, trace it to the carburetor. Check the carburetor bowl for fuel.
Check the spark plug, the magneto, any switch that breaks the circuit or kills the circuit for spark.
If you're getting good fuel to the carburetor and you're getting good spark, try to start it with ether spray.
You might also want to check compression while you're checking everything else.
Jul 26, 2014 | Onan Marquis Gold 6500 Lp
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
My onan 2.8 gen. starts but quits when i let off the starter button, what can i do to fix it
maybe old gas or dirty carburetor first replace the gas if nothing happen open your carb and clean the pilot of the carb its one small screw w/holes inside most times get clog
Apr 14, 2013 | Onan Cummins 2.8 KVD-2090 RV QG 2800 RM...
I HAVE A 5.0BGE ONAN GEN SET IN MY RV IT RUNS BUT THERE IS NO ELECTRICAL POWER TO RV ALL FUSES AND BREAKERS OK. ANY HELP APPRECIATED
Possible solution: if it's been sitting idle for some time, you might need to flash the windings. see this link:
http://www.endtimesreport.com/dead_gen.html
If you're uncomfortable doing it yourself, your Onan dealer can do it in 10 minutes.
Don't forget to check the circuit breaker on the generator itself!
Sep 01, 2011 | Watts Onan Portable Generator - 4000 ,...
I have an onan 5500 gas generator that wont start
What is the model? Chances are the carb needs cleaning or replaced.
Sep 21, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Aug 29, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
625 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
