Question about Samsung SCX-4725FN All-In-One Laser Printer
PCL6 error - sb_count != -128 how do I fix this?
Control panel shows an error message 128 MB. No buttons ie menu, tick will do anything. Have turned the printer off, unplugged it, removed the internet cable!!
Its not error message, its hanging at memory count. Remove memories clean the contacts insert once again check if its not resolved primary inspection memory/DIMM, secondary formatter..
Sep 29, 2011 | HP LaserJet 4700 Printer
Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Dec 07, 2008 | Xerox WorkCentre M15i Laser Printer
Pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
Sep 19, 2008 | HP LaserJet color laser printer
Casio FA-128
how to upgrade Casio FA-128.
Dec 17, 2007 | Casio Boss Business Organizer
PCI sound card not working
Do you have WIN XP installed?
What speakers are you using?
are they surround sound or regular
Nov 21, 2007 | Asrock K7S41GX Motherboard
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Samsung SCX-4725FN All-In-One Laser Printer Logo
1,199 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
