Question about Bosch Classixx WFL 2066 Front Load Washer
Machine vibrating and grinding at the bottom of the machine
    Sergeant:
  • 228 Answers
If noise stops when you put youre hand on bottom panel(vibration) then it will probably need a new drain pump as they wear out they can become noisy and make the panel buzz.
Posted on Oct 20, 2009
My washer makes a grinding noise and leaks out the bottom
washer makes a sqeeling noise where fan belt is attatched but only in one direction.could the machine need rebalancing?
Feb 21, 2013 | GE WBSR3140DW Top Load Washer
My new Maytag Bravos HE top load MVWX500XW vibrates during spin, is this normal?
from the way you describe the issue it sounds normal, all washers vibrate at least a little or alot (depending on the balance or unbalance of the load) if it is just vibrating and not making a grinding or scraping noise it is fine, if its vibrating too much for your like, try to rebalance your load.
Oct 03, 2012 | Maytag MVWX500XW - Bravos XTM HE Top Load...
Ford Explorer 2002 grinding and vibration under 60 mph
you have wheel bearings failing
the random abs light is the rotor for the sensor touching the sensor head because the wheels are loose on the shaft
Apr 15, 2017 | 2002 Ford Explorer
M/N ETW4400SQ0 The small pin, 2" with cotter pin hole in the end, underneath the machine, with a opaque capture shield has come loose from the spring it holds? In turn during spin cycle the...
Hello Mike
Those cotter pins with the shield over them were part of the shipping braces from when it left the factory and they do have no bearing on the suspension system.
What most likely thats causing it to vibrate so badly are the cresent shaped plastic peices that fit between the plates under the outer tub,Their is 2 types of those on the washer one fits under the bottom plate and one fits on the top of the bottom plate andin between the upper and lower plate. They are impregnated with teflon and have worn out so instead of the plates sliding free the are grinding against each other
Those parts are called suspension pads,the part number for them is 285744 &285219 they can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
This link shows where they are they are item numbers 13&15
http://www.searspartsdirect.com/partsdirect/part-model/Estate-Parts/Washer-Parts/Model-ETW4400SQ0/3191/0153200/W0607071/00005?blt=06&prst=0&shdMod=ETW4400SQ0
GENE
Sep 24, 2011 | Whirlpool Washing Machines
When i turn power button on ,it sounds like grinding metal ,very loud vibrating noise.
sounds like the bearings. make sure machine is off open door put your hand at the front of the drum at the top then see if you can lift it up and down if there is alot of movement it will most likely be the bearings,or try turning the drum by hand to see if you can feel any vibration or hear any grinding noise.
Jul 26, 2011 | Washing Machines
When i get on the gas i hear a grinding noise
is it a grinding noise, or vibration noise, as sometimes the heat shields can produce a vibration noise that can be misheard as a grinding noise......does this grinding noise go away as you brake ????...do you hear it more whn you go left or right ???
Dec 20, 2010 | 1997 Jeep Grand Cherokee
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Vibration of the wash mashine
How old is the machine? Have transit bolts been removed? Older machine is possible bearing failure or spider breakage( a 1 in 10 wash with a temperature of 95 degrees celcius will extend life of a front loader!- an empty wash or towels or sheets at this temperature). A grinding noise can simply be a worn drive belt, rotating drum by hand and finding grinding and lateral movement equals bearing/spider failure. Also a simple case of Underlaoding the machine will cause unbalanced load and vibration.
May 22, 2009 | Washing Machines
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Mar 07, 2008 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
225 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
