Question about Briggs & Stratton Garden
Engine seems to run out of fuel after running & pulling for 5 min
Engine seems to run out of fuel after running & pulling for 5 to ten min. Has to be choked to continue runnin. B&S model 422707 2 cylinder
  • 472 Answers
SOUNDS LIKE YOUR CARB NEEDS TO CLEND OUT AND A CARB KIT PUT IN LET ME KNOW IF THIS HELPS
Posted on Oct 08, 2009
Will start and run for ten mins then dies. If I wait ten mins will run again. Fuel filter is empty when it dies
Sounds like you got the wrong filter. There are filters for fuel pump tractors and filters for Gravity fed engines. I had the same problem when I changed my filter. I had to get one that was gravity fed
Oct 17, 2015 | Cub Cadet Garden
John deere lt133
Engine oil does a couple of things, lubricates and cools. Your crankcase probably takes about 2 qts. Fill it to full and park it over something clean to see if there are leaks.
For your engine to run it needs fuel and air. If the engine is dying, more than likely you have a fuel/air issue. Check your fuel lines for leaks, replace your fuel filter. Clean or replace your air cleaner. Make sure your tank cap can breathe, so air can replace the gas going to the engine.
Jul 19, 2014 | John Deere Garden
I have a 1989 S10Pick up with a 2.8L, won't stay running. I can pull the ecm b fuse it will run about a min then quit, I've changed the fuel pump relay and checked crounds still has this problem?
if it runs for about 5- 10 minutes before it stops, when it stops remove the gas filler cap, do you hear a suck inrush of air when you remove the cap?
Dec 15, 2013 | Twister Auto Parts 89-93 Chevrolet S-10...
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
I have a Yard Machine 5.5hp 2-stage snow blower. I bought it used but I think it is a lightly used 2004+-. I use the primer bulb and it will start within 2 pulls, runs beautifully. I slowly open the...
The running time seems to indicate a plugged fuel tank vent. Try opening the cap to see if that will allow continued running. Many engines have the vent within the cap itself, while others vent from the air cleaner through a line. Ignore the fuel drip on the adjustment screw. Hope this helps!
Dec 27, 2010 | Garden
1994 intrepid runs for about 5 min then dies and wont start back
change fuel filter or coolant sensor reading cold engine allthe time & causing eng. to run rich & stall
Aug 19, 2009 | 1994 Dodge Intrepid
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Eclipse won't idle .
Throttle body, IAC or EGR valve.
Mar 12, 2017 | 2003 Mitsubishi Eclipse Coupe
Garden Logo
224 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
