Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I just replaced my battery and my code no longer works. To change it or anything it wants my code. I figure there must be a base code they all start out with, what is it?
  • Don Maggard May 11, 2010
    Are you talking about a keypad for your garage door opener?
    President:
  • 3,197 Answers
Just input your present code.
Posted on Oct 13, 2009
How do i change battery
1. Pull the battery cover off (away from the base) in a downward motion.
2. Install one new "CR2032" battery into
the battery compartment, with + facing
outward.
3. Replace and fasten the battery cover
securely.
Jan 12, 2013 | Lumiscope 2215L Digital Ear Thermometer
I own two SAVV VAC-IR14 wireless headsets that I use with my SAVV video DVD car player. I am no longer able to hear anything through the headsets. I've replaced the batteries but no sound. Any...
Try checking the base-station and the frequency they're tuned to.
If they both all of a sudden didn't work it must be an issue with the player or the base-station.
Hope this helps!
Jul 04, 2011 | Savv VACIR 22 Wireless Headphones
My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
Mar 27, 2009 | Televison & Video
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
GE 900mhz model 26936GE2-C
Sounds like a defective battery or low battery.
1. Have you replaced the battery?
2. Have you changed the channel?
3. Have you dropped it?
Answer these few questions and we'll see if we can figure it out.
Let me know.
Feb 18, 2008 | Xact Communication XG2200 Cordless Phone
Phillips VOIP841 skype phone
DeRegister the handset and then reregister it to the base
On handset
Menu
Settings
Handset
Deregister
Then
1 ) press Reg. Register shall be highlighted.
2 ) press Page key on the base unit until the two indications turn off.
If registration is successful,the signal icon 070928095554_21019.bmp displays steadily.
If registration failed,repeat the above procedure.
Sep 17, 2007 | Philips VOIP8411B/37 IP Phone
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
109 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
