Question about Sony Cyber-shot DSC-W55 Digital Camera
The zoom is not working when I'm taking pictures. "Turn the power off and on again" appears when I'm using the zoom lever. But when I'm viewing the pictures that I've taken, the zoom is working...
SOURCE: Cannot Take Pictures Anymore...
Green, I spent some time today with a sony tech rep on line. We went thru the motions of battery, memory card and still no help. So I'm sending my camera back to sony for repair. Mine is still under warranty. Hopefully yours is too. Good Luck. Mike aka m1stones1
Posted on Aug 28, 2006
  • 8 Answers
sony has recalled some cameras due to the LCD screen problems..I called today because my local camera shop told me there was a recall my model..so Sony is sending me a shipping label and fixing it at no cost...
Posted on Aug 31, 2007
SOURCE: turn the power off and on again displayed
Because I'm a moron, I didn't know that some companies sell broken digital cameras on eBay. As a result, I bought a broken DSC-W80 that shipped with the lens extended and the turn on/turn off problem. I noticed that the top part of the lens was crooked. I was able to firmly pull the lower end up so that it was level. It snapped back into place and now works wonderfully. I guess it was worth the $113 + shipping.
Posted on Dec 06, 2007
  • 11967 Answers
SOURCE: "TURN THE POWER OFF AND ON AGAIN"
This may be a lens problem. Try these... Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 02, 2010
SOURCE: The camera won't stay powered on. Battery is new.
thanks, problem solved!
Posted on Jul 09, 2010
Hi! I am having Fujifilm S1000fd digital camera. I have two issues. First one is with SD Card. Just yesterday i were having difficulty of viewing some pictures in the camera. At one zoom knob doesnt work ...
The zoom button is not for browsing the pictures.
Use the 4-way switch to browse the pictures.
It appears that there is something wrong with your SD card. Format the card in the camera before using it again. Make sure you have saved all images to the computer before formatting.
You have a faulty battery. Try cleaning the contacts on both the batteries and the charger.
Jul 18, 2011 | Fuji FinePix S1000FD Digital Camera
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
DID NOT SHOW THE VIEW TO TAKE PICTURE INSTEAD IT
I THINK ITS A MEMORY STICK PROBLEM. PLEASE TURN OF YOUR MEMORY STICK AND TAKE PICTURE AGAIN . I THINK IT WILL BE WORK.
MY ADDERSS IS : bony_don@yahoomail.com
Mar 13, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
I bet you can't solve this.
We have a Canon A520 and it was having all the symptoms noted. Searched for a resolution on numerous sites including the Canon Support site. While on the Canon Support site, I found an FAQ on "How to RESET the A520". Turn camera on, find and hold MENU button for 5+ seconds until "Reset settings to default?" screen appears. Arrow over to OK and press the SET button. When we did this the battery low indicator showed, replaced batteries with standard alkaline batteries. Everything functions properly, with no additional problems for the past 5 days. I guess the camera just lost its mind and had to be defaulted and rebooted, hope this helps.
Oct 01, 2008 | Canon PowerShot A520 Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Hey BLOBO123,
I would have the camera looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. The flap that holds the batteries in could possible be purchased from the manufacturer and is probably pretty easy to replace, but the lens is usually much harder and expensive to repair. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Does not zoom in or zoom out
Hey Ulviya,
What is most likely going on is something is obstructing the movement of the lens (i.e. sand). You could try blowing compressed air into the side of the lens to try and dislodge whatever might be in the lens. If this doesn't work I would try putting the camera on a flat surface with the lens pointing upwards and hold the shutter button in, while doing this turn the camera on. If neither of these options work I would have it looked at by an authorized service technician, and it’s possible all it needs is a professional cleaning. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
A spot appears in same location on every picture
take the lens out and blow air inside the camera and on the inside part of the lens.
Jan 10, 2008 | Nikon D40x Digital Camera
Video Problems
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to normal_mode.gif.
mode_dial.gif 3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Jun 10, 2007 | Canon PowerShot A400 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
19 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
