Question about HP ProLiant DL360 G5 Server
RHEL 5.3 fails to boot at "bringing up interface"
Hi, I have a RHEL 5.3. I was trying to change the host ip address on the bonded interface made from 2 Broadcom interfaces.
I run the "system-config-network" script and change the bond0 ip address from 10.1.1.5 to 10.1.1.3.
Then restarted network service. The host lose netwok connectivity, doesn't respond to either .5 or .3.
I reversed the change, and the host start working again.
So I rebooted to make sure that its working fine and bam!!
The server hang during boot, on the console the last two lines says:
Bringing up loopback Interface: [ OK ]
Bringing up Interface bond0: ?
? means flashing cursor.
The console is respnsive, you can type, but the OS is stuck at this point.
What should I do to overcome this?
Thanks in advance
  • gpftest May 11, 2010
    The actual problem was not with the HP Proliant but with "RedHat Enterprise Linux 5.3" I was confused when loading "My Products"
I found the solution.
Take in accunt that I'm a total newbie on Linux boxes.
1 - Previous to any change, following RH deployment guide, I backed up the network config on a file called "network-config-10.1.1.5" with:
"system-config-network-cmd -e > /root/network-config-10.1.1.5"
2 - After the Server refuses to complete boot sequence, I rebooted the server and entered on interactive mode pressing "I" just after RHEL splash.
3 - Then I accept all options with "Y" but "Bring up interface bond0".
Then hit "C" to complete boot sequence.
4 - Login normally as root and revert the changes with:
"system-config-network-cmd -i -c -f /root/network-config-10.1.1.5"
5 - Reboot the server and all return to normal.
Posted on Oct 08, 2009
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
Jul 19, 2011 | Acer Aspire One PC Notebook
Steps to install linux through server?
Hi..
Let me show some basic steps which will help you to install RHEL through server or Network
Before we start, i would like to point out some informations
  • Steps shown here are explained with RHEL 5. But the procedure is same for all versions of RHEL which supports Network installation
  • For the Convenience to take snapshots, i'm installing RHEL on a VMware (Virtual Machine). So to me, some hardware resources are limited like physical memory, hard disk space, Graphics adapter ..etc
  • My Server which contains RHEL images is " LinuxServer " and its address is 192.168.75.100
  • Location of RHEL5 Installation Image on this server is: /home/nightflare/Test/RH5/i386
    Shared folder is: RH5/i386
    So if we want to access this folder through network, then the address would be : 192.168.75.100/RH5/i386
  • Due to limited hardware resources of my machine, i would proceed with TEXT MODE installation which is no different than the Graphical Mode.
So lets start.
I have a bootable CD of RHEL which i will need to start with. You can use any live CD or DVD of RH ( which support network installation ) to start the system. I inserted the Disc and set system to boot with it.
1. START THE SYSTEM TO BOOT FROM THE LIVE MEDIUM
If you successfully able to boot from the live CD / DVD, you probably will get a screen like this
Type next to the boot: linux askmethod text and press
The option "askmethod" will set the installer (anaconda installer is default installer for RedHat) to ask us for which installing method should be used. RedHat Linux supports many installing methods like
  • CD or DVD (Local CD / DVD are supported. If you want to use Remote CD/DVD, you will have to mount it in a shared folder and proceed with network installation method)
  • Hard Drive (installation files stored)
  • NFS Image (images stored in Network Filesystem Partition over a network)
  • FTP (Installation files stored on FTP Server)
  • HTTP (Installation Files stored on HTTP Server)
The option '" text " will tell installer to use TEXT MODE installation. If you prefer Graphical Mode installation, you can skip this option.
After pressing Enter Key, the anaconda installer will load necessary files and drivers to memory and start the second level of installer. You will see,
2. SELECT LANGUAGE AND SET LOCATION BASED PREFERENCE
After essential drivers and files are loaded, installer will ask for installation language, keyboard etc.
I select English as my installer's Language
On this screen, Choose the layout of your keyboard. In Most cases, The Keyboard Layout is USA, so is mine. But if your layout is different, choose appropriate Keyboard Layout.
I Choose US
3. SELECT INSTALLATION METHOD
Since we start the installer with askmethod , installer will ask for the method of installation.
I chose HTTP, since my RedHat Server is HTTP server.
4. CONFIGURE NETWORK
When we chose Network Based Installation, Installer will prompt for configuring the network.
On this screen, Select what all IP technologies we want to be supported by the installer.
After selecting the IP configurations on previous screen, the installer will look up and resolve IP addresses.
After resolving IP Addresses, Installer will ask you for location of installation files on the network
Since we selected Installation over HTTP , we need to specify the server (Host name of server) which contains the binaries or installation files. And we needed to specify the location of the installation files in the server. Remember this location is relative to server and web accessible directory
ex.: in my case Server Hose name is LinuxServer and IP of server is 192.168.75.100.
Installation image is located under /home/nightflare/Test/RH5/i386
But the location should specify on this screen is /RH5/i386 NOT /home/nightflare/Test/RH5/i386 or 192.168.75.100/home/nightflare/Test/RH5/i386
After entering the details necessary to find the installation images, it will try to get those files.
If everything went fine, then it will try to pull the files from server.
If you see this screen, you can relax. System successfully found the installation files on server and retrieves it.
5. SET INSTALLATION
Rest of Installation is just same as Installation by Local CD/DVD
Just Skip this window. RHEL also comes in CDs which spans over many CDs each with a installation no. like DISC 1, DISC 2 ... etc. This is not our case, so we can skip it safely.
This screen ask to confirm our option to Skip. Choose Skip
Searches our system for any previous installations of RedHat
If Any previous installations were found, installer will ask for whether to Upgrade the previous installation or we need to Reinstall. I choose to reinstall
On next screen, we are requested to specify the partitioning. We can either accept the Proposed Partitioning or proceed with Custom Partitioning.
I Choose Custom Partitioning as it will provide more control over how the spaces are alloted ..etc.
Since I go with Custom Partitioning, I can edit, create and even modify partitions according to my needs.
Remember, I'm working on a VMware. In real cases you may dealing with larger disks or able to set up LVM or RAIDs
Select Whether Need a Boot Loader or not
On This screen, we can choose have extra boot options or not. Booting options are like typing single will cause kernel to log in to single user mode rather than multiuser mode
[ Sorry, fixya says this post exceeds max message lengh ]
Feb 19, 2011 | Red Hat Enterprise Linux ES Basic Edition
I am getting an oracle error while trying to login. The error says: ORA-12545; Connect failed because target host or object doesnot exist. What could be the probable error?
ORA-12545: Connect failed because target host or object does not exist Cause: The address specified is not valid, or the program being connected to does not exist.
Action: Ensure the ADDRESS parameters have been entered correctly; the most likely incorrect parameter is the node name. Ensure that the executable for the server exists (perhaps "oracle" is missing.) If the protocol is TCP/IP, edit the TNSNAMES.ORA file to change the host name to a numeric IP address and try again.
Aug 16, 2010 | Computers & Internet
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Ploblems with dmz-outside (webpage). pix
Remove this line:
static (DMZ,INSIDE) 10.10.0.0 10.10.0.0 netmask 255.255.255.0
You don't need a translation going from a lower security level to a higher one. You will also need a nat line for the dmz so that pc's on the dmz will be translated outbound. The only connection that will work on the dmz is the webserver when he's sending traffic outbound with a source port of 80. Something like:
nat (DMZ) 101 10.10.0.0 255.255.255.0
Other than that, it looks like it should be working. You've got permission, a route, and a translation. Maybe "clear local-host 10.10.0.2" to get rid of any bad xlates and try again. Check debg level syslogs, run packet captures, "clear asp drop" then "show asp drop" after an attempt?
Feb 28, 2009 | Cisco PIX Firewall 506
Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Feb 01, 2009 | Cisco Catalyst 3750E-48PD
No gui during installation of RHEL 5 on acer 5920 notebook
Hi Jay
may be the following link helps u
http://www.linuxtopia.org/online_books/rhel5/installation_guide/index.html
Jun 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
Cisco asa5505 problem
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
Apr 16, 2008 | Cisco ASA 5500 Firewall
HP ProLiant DL360 G5 Server Logo
870 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
