Question about Logitech Cordless Desktop MX 3000 Laser Keyboard & Mouse - 967553-0403 967553
The side keypad numbers do not work What can I
The side keypad numbers do not work What can I do ?
TURN ON (NUM LOCK) THERE WILL BE A NUMLOCK KEY ON A FULL SIZE KEYBOARD OR IT WILL BE ON THE SAME KEY AS F11 IN THAT CASE HOLD FN+F11
Posted on Oct 08, 2009
Can't get the number lock key to work
Windows Key + U
Click 'On Screen Keyboard'
Bottom right hand side there is a button says 'NumLock', it will be white if on, black if off.
If this OK and not working, it sounds like the keypad itself is faulty. Try a factory reset before deciding to change the keypad. BIOS reset also may help.
Dec 01, 2012 | Dell Vostro 1500 Notebook
While using an USB number pad, every key strike shows an on-screen display for NumLock. How do I disable this feature?
The number lock key is located on the right side of your keyboard near the extra number keypad. it is in the top weft hand side of the number keypad. it says " Num Lock" on it and has an arrow pointing upward (usually). If you start with the last key on the right side of your keyboard it should be located four keys over.
Press it to turn on and off the number lock feature.
Mar 20, 2011 | Computers & Internet
Keypad on right side doesn't work
Try pressing your numlock (top left of the keypad) and try the numbers again. Try your keyboard in another computer -- if they still dont work, you have a hardware failure ... time for another keyboard. If it works on another computer, then I would recommend right-clicking on "My Computer" and selecting "Manage". Go into the hardware manager, and delete your keyboard, and reboot. The Windows will find your keyboard and reinstall the drivers, hopefully resetting whatever configuration was previously blocking your keypad keys.
Apr 10, 2010 | Apple M9034LL/A Keyboard
How can i get the keypad code to unlock my 2005 ford explorer?
The factory keypad code is the bold numbers listed on the side of the keypad module, should be located under the drivers side dash on the left, look for the numbers that are in bold type. Hope this helps, let me know
Dec 14, 2009 | 2005 Ford Explorer Sport Trac
Right side of the key pad doesn't work (Numbers 3,6,9)
I have the similar problem.. Only portion of the keypads work. I had a guy come out and take a look and he said that I need a new touch panel which would cost me ~$450.. I am trying to find parts on-line to fix it myself.. let me know if you find one.
Jun 21, 2009 | Jenn-Air JGS8850BDS Stainless steel Gas...
Nokia 6233 Keypad NOT WORKING!!!
change keypad and use k750i see the keypad socket on up side and do some changes their
Jun 14, 2009 | Nokia 6233 Cellular Phone
Key pad
open the front key face by placing a card on the side of the phone. careful not to poke it harder as there are some chips inside the front slide. once it is open, clean it or try to adjust the keypad face then place it back. If problem still exist, bring it to the mobile center for repair.
Apr 09, 2008 | Nokia N81 Smartphone
Numbers 1,3, 4 and 6 no longer work
It's probably the keypad. The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it. At power-up, the display should flash or show a text
message. If not, a key may be stuck due to a foreign substance or a defective keypad.
We have critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board. To check that:
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
Also, you must have the door closed for the START button to work.
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 05, 2008 | Sharp R-320H Microwave Oven
Keypad not working when phone in use
There is a button on the left side of the phone which pops up the keypad.( dauden )
Mine registers just fine. (born2shop)
Dec 23, 2007 | LG Prada KE850 Cellular Phone
Keypad tones - D900i
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Oct 07, 2007 | Samsung SGH-D900 Cellular Phone
Computers & Internet Logo
75 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
