Question about Vizio VP322 32 in. Plasma TV
Vizio tv clicks on and off for a while untill it warms up.
It is getting worse and worse. I was wondering how much it costs and what the problem actually is. People have had the same problem so please reply!!! Can i fix it myself......I am very handy
  • 3 Answers
This is a power supply board problem.
I fixed this problem by replacing the board. The model number for my board is EAY42539401. It cost me $55 plus shipping. A Google search for the board model number should bring up a few suppliers.
I recommend fixing it yourself if you can (all you need is a screwdriver). Replacing it yourself is MUCH cheaper than having it repaired. It took me about 45mins to fix (all the srews). I purchased the board from ModusLinkPTS.
http://www.moduslinkptstvboards.com/EAY42539401-P10344.aspx
Posted on Oct 15, 2009
I have a 55 Vizio 3D smart tv. This picture color fade in and out to the point that I cannot watch tv. I this a problem with the main board?
Hello Patricia,
  • There is a loose soldering connection in the Main Board. That happens because the components on the are generating a lot of heat therefore melting solder connections.
  • Stop beating on the TV's back, that only makes the problem worse.
  • Take it to a shop.Or if you are a tech, try locating the loose connection(s) and solder it back.
  • Also check your Warranty Period, It may cost you 0$. Call Vizio if you still have Warranty on the TV.
Here is a link to Vzio Supoport.
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jun 25, 2015 | Vizio M3D550KD 55 inch Class Razor LED...
Vizio SV370XVT with LONG Warmup...Power Supply? Mainboard? T-Con?
There should be no problem related to warm-up to flat panel TVs. It is only related to CRT based TVs. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 02, 2015 | Vizio Televison & Video
Blue spots on vizio plasma tv
Going to be hard to determine which board is bad since it does it when it gets warm---could be main signal board or?
Mar 31, 2012 | Sony Televison & Video
My vizio tv keeps shutting off
If it turns on reliably but won't stay on, try putting a portable fan pointed at the rear of the set.
If this prolongs operation, it may be a semiconductor at fault or an early warning of a common problem caused by chemical (electrolytic) capacitors going bad in the switched mode power supply.If this is the case, the problem will continue to get worse until it no longer turns on at all.
Jan 01, 2012 | Vizio XVT3D474SV 47 in. 3D LCD TV
My flatscreen tv is distorted
Speakers can cause problems with the correct display of video on TVs but usuall it only concerns direct view tv. Projectors should not have any problems or flat screens. I think you have a different problem Explain better what you mean by distortion in the JVC. Let me know and I will try to help you.
hardrocko
Feb 06, 2010 | JVC LT-42E478 42 in. LCD Television
I have a Vizio 42LCD TV, no sound and no picture. It just went black all of a sudden. I was just wondering what it could be. The tv was purchased in 2006, so no warranty. It would problably cost too much...
I would at least remove the back and
look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
You can get the new power supply module (make sure it matches the picture on the website) here (which is more likely): http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VO47L+
Dec 07, 2009 | Vizio VO47L 47 in. LCD TV
Yellow light is so I have power but remote or
Its a vizio l37. I bought it in 2004 from Sams and haven't had any problems until now. We took it to a repair shop and they charged me $55 to tell me it was dead. They said they could fix it by replacing the main board which costs $250 with an additional $250 in labor. We said no thanks to the $500 repair and bought a new tv for $600. Now its in the garage and I'm wondering if there is something I can do to fix it for less. Seems like a waste.
Jul 29, 2009 | Vizio L37 Television
Repairman for your TV yet?
Actually I found quite a bit of info regarding the problem and confirming that it has to be the caps on the hyperboard as hdtvman was mentionning.
I've bought the caps for less then $3, and will give a try at replacing them probably next weekend. I have nothing to loose as it's getting worse day by day now. If I screw up I can alway order the hyperboard from PTS...
Jul 27, 2008 | Toshiba 50HX81 50" Rear Projection...
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
Vizio VP322 32 in. Plasma TV Logo
1,113 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
