Question about HP Photosmart M525 Digital Camera
Battery/memory card door is broken. - HP Photosmart M525 Digital Camera
I havent used my olympus tg310 for a while and its been in good storage so I need to use it now and when the waterproof seal thing where the battery and sd card is when thats open it works but as soon as I...
Carefully scrutinise the battery/memory card cover. In the camera is a switch that supposes to tell the camera if the door is locked correct or not. Perhaps something is blocking the correct working of that switch. Clean the inside of the battery / memory card holder and its door.
Open and close the door several times and hope he switch starts working as it should. I hope there is no spring broken or blocked.
Success
Jan 27, 2014 | Cameras
Problem started with battery door
The door has an interlock on it. You probably broke the door. The door on some of these cameras can be replaced from the outside. You must make sure the interlock switch is not broken as well. The tabs on the housing of the camera can get bent or snapped off if enough force is used.
A broken door will be $75 there abouts, installed.
A broken detect switch, adds about $45 (A board).
A broken case may set you back an additional $75
Apr 16, 2010 | Canon PowerShot SX100 IS Digital Camera
The camera FujiSD8000 i have won't turn on. Used fresh batteries, has not gotten wet, but i was recently involved in a car accident and the camera was in the car with me when it happend. The camera looks...
Check the memory card or battery door for the tab that activates the cut out switch. It ,or the switch, may have sustained damage. I'm not 100% on this model but if it's like the S5700/ S5800 models then the memory card door has a tab for the cut out switch to prevent card removal whist powered up.
Apr 08, 2010 | Fuji FinePix S8000fd Digital Camera
Broken battery /memory card door. Just need a new
Sign in to ebay auction, type and click onto digital camera parts and buy a nonworking camera like yous for parts.
Nov 25, 2009 | Cameras
The door to lockdown my memory card is broken what do i do ?
I've done some searching and all I could find is a replacement memory card door at bbrepairshop.com. It's fairly pricy, especially after shipping and handling charges are added, but, like I said, it's all I could find.
Dec 21, 2008 | RIM BlackBerry Pearl 8100
Have put in a memory card, But camera keeps displaying memory card full
Try reformatting the card. Use your camera to do it, not a computer.
Dec 14, 2008 | Cameras
My vivitarN1659 will not reconize a1gb memory card and either states that the memory is full or that the memory is locked
There should be a tiny lever on the side of the memory card. Unlock the card by pushing the lever up. If it still says memory card is full, take out the battery and push the memory card further into the slot. It should not move while it is in the slot. If it "floats" when you close the battery door, it is not down far enough into the slot. Return the battery and close the door.
Oct 05, 2008 | Cameras
Broken memory card/battery door
I found this site with some replacement parts and battery doors looks the same. I dont know if is original. I also have the same problem. If any of you have found the part in a different web site.. just let me know please.
Jul 31, 2008 | Cameras
Problem with canon
Check the CF connector in the camera. One of the pins might be bent...
Dec 08, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Broken door
Tape it shut is the only solution here No Spares no Repairs.
Jul 06, 2007 | Pix S-470S Digital Camera
HP Photosmart M525 Digital Camera Logo
23 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
