Question about Lexmark X3480 All-In-One Printer
How do i change the cartridge on the lexmark 3480. I have lost the manual.
    President:
  • 1,564 Answers
When you open the section at the "waistline" of the machine the inks will center themselves automatically giving you clearance to change them.
Posted on Oct 07, 2009
    President:
  • 1,126 Answers
2 Suggested Answers
  • 320 Answers
SOURCE: How do I change the ink cartridge on lexmark x3480
Please use lexmark solution center... here it is:
To install a cartridge using the Solution Center:
  1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
  2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
  3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
  4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
  5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
  6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
  7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
  8. Make sure the cartridge cover is closed and that there is paper in the printer.
  9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
  10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
  11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
  12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
  13. You can now exit from the Solution Center.
Thank you......
Posted on Jan 31, 2009
Lost cd for lexmark 3480
You may download the software for free from here.
Nov 07, 2012 | Office Equipment & Supplies
Lost my manual, need to change the ink cartridge, help
  1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
  2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Ink cartridge
If you have a 3470, you need a #1 cartridge. If you have a 3480, you need a #2 cartridge. If it is a 3400 series, there is only one cartridge. It lets you print both in color and in black.
Jan 22, 2009 | Lexmark X3470 All-In-One InkJet Printer
Thank you......
Jan 15, 2009 | Lexmark X3480 All-In-One Printer
I have a Lexmark 3480. Although the lid is closed it tells me that it is open. Can you help me on this please. Many thanks Roberta
You have probably broken off a small pin on the back of the cover that you open when you are to change the ink cartridge. Had the same problem my selv. This pin touches, when cover closed a small button that gives the printer a signal that the cover is closed. Solved this with putting something on that button, and taped it so it wouldnt go away.
(please excuse my not to good english)
Nov 07, 2008 | Lexmark Office Equipment & Supplies
I have lost my CD for loading the print driver for my Lemark X 3480 printer. My version of windows Xp. Please can you send me a way of being able to load the driver. Thanks Liz
the driver will be available from www.lexmark.com then select Drivers and Downloads, then driver finder, type in X3480 into search box and press GO, select your OS
Jul 06, 2008 | Lexmark Office Equipment & Supplies
Lexmark X3480 All-In-One Printer Logo
217 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
