Question about NetGear SPH200D IP Wireless Phone
I cannot enter phone menus. It is always on "system starting up". I made firmware upgrade, no change. Entering the webpage for the base, i can see it is connected to internet, but not to Skype. Please help
  • rspopescu Oct 07, 2009
    I can access the web interface of the phone, as I said, it sais is connected to LAN.
    I can ping it, it is working.
    I tried DHCP or Static IP, but is still not working.
    The web acces page of the phone is all working, except the "skype" page.
  • rspopescu Oct 08, 2009
    Thank you, this is it...
    Guru:
  • 1,049 Answers
"System Starting Up" usually comes up while waiting for an IP since the system loads rather quickly. Plus you've already flashed the system, so you know it is clean. I know you can see a light indicating a LAN connection but are you really sure it's connecting to the Internet, or just to the router?
Because I suspect the phone is just not resolving an IP or that your Firewalled from Skype. You would get a light regardless, if it is attached to the LAN with or without a valid IP, but would not actually be on the Internet. So Skype would not be able to connect. Although I know you probably checked, a firewall would cause a similar error as Skype requires both port 80 and port 443.
I would go onto the web interface on your router and see if the phone is actually being recognized as a device, see if it has leased an IP, and check that you have not limited DHCP in some way. Also try pinging the phone's IP from another device, since your router should tell you what IP was assigned to the phone. If you are home, you may even want to try running the phone directly into your DSL or cable modem to test it.
I believe one of these would fix it, but if everything else is good, I would then start suspecting a hardware issue.
Posted on Oct 07, 2009
  • NA NA
    NA NA Oct 07, 2009
    I know you reloaded the firmware, but if you haven't already, try resetting the handset to factory defaults, resetting the base, and starting the whole installation from scratch. Again, check the device with just your modem (no router) and see if it makes a difference. I have also read that there are some issues with the v3 beta of Skype in
    conjunction with a cordless Dualphone, maybe you need to roll back to
    the old firmware and try again.
    Also, I know hearing that this could be related to hardware seems like a cop out on my part, but keep in mind that this model of phone was riddled with problems, the forums are filled with similar complaints; and it is now well past it's end-of-life. The phone itself operates independently of the Skype service, which may have changed slightly. Some people it works, some it doesn't. It is very hard to trouble-shoot a device that is dependent on an external service.
TP-LINK TL-WR541G Router how to change the language Chinese to english
  1. Make sure you know your hardware version!
  2. Download firmware update in English from TP Link website and unzip.
  3. Connect computer to router with Ethernet cable as per manual and in your web browser window enter http://tplinklogin.net then enter user name and password (admin,admin) to access the router Configuration Utility.
  4. From the English manual note the location in the configuration utility menus of the firmware upgrade utility. I.E. Go "system tools" (last entry in menu) then "firmware upgrade" (3rd item down). I know it's written in Chinese but you can count right?
  5. Select your unzipped file location in the window and press the button beneath.
May 10, 2014 | TP-LINK TL-WR541G Router
My wrt120n was hacked. login password was changed and i cannot login into the conf webpages. I do have physical access to the router. I tried to do the following after some search on the internet 1....
Please reset the router by pressing the reset button while your router should be plugged in to the power cable.
While reseting the router the lights on the router should be blinking for 30 seconds.
Try this this should work.
Apr 28, 2013 | Linksys WRT120N Wireless Router
Momentus 5400 fde.3 formatting error
Which operating system ?
If windows 7 click start richt click on computer select properties then device manager scroll to your disk (hard drive) expand right click select update drive software
Every Seagate drive requires a few firmware updates during its lifetime.
Seagate firmware must be up-to-date to ensure that the product will run reliably.
Changing the firmware on a Seagate product to a more updated version will improve the product's performance.
Check the Seagate website often for any update available for your drive.
The firmware can be changed with just a few clicks of your mouse on the Seagate Web page.
Click the "Start" button on the bottom-left corner of the screen.
In the window that pops up, click " My computer " or just "Computer."
Another window will show up with an icon for your hard drive.
Right-click the hard drive icon and press the "Properties" option.
This will tell you what model your hard drive is.
For example, your hard drive might be ST31500341AS.
Open your Web browser. Type in www.seagate.com and press "Enter" on the keyboard.
Wait for the webpage to load.
Enter the word "Firmware" and your model number in the search box on the upper right hand corner of the webpage and press "Enter" on the keyboard.
Using the example from Step 1, type in "Firmware ST31500341AS".
Click on the first link that is returned in the search results.
Locate the firmware update. Double-click the update.
Press the "Download Firmware Update Utility" link to start downloading.
Click yes on any pop-up boxes that you may see.
Open the new firmware file by double clicking the file that you downloaded in Complete the installation by accepting all of the default questions that are asked during the installation process.
Hope this helps
Nov 03, 2012 | Seagate Momentus 5400 FDE.3 320GB Hard...
Cisco 7911G definitely dead?
You are very close to fixing your problem. You will need the correct firmware and files; these are proprietary but you should be able to acquire them from your certified reseller. Alternatively, here at IdacomUSA, we have the proper firmware on hand, and can flash the phone for you to get it back to life. Call us at 1-800-903-9190 or visit us at http://idacomusa.com
Jan 13, 2010 | Cisco 7912G IP Phone
Wrt 54g setup page will not completly load
Hi friend, Please follow the steps 1) open the website www.linksys.com/download 2) there in the first page of the website you need to enter the model number of your wireless router and hit Enter 3) in the second page you will see an option Get downloads and drivers,click that. 4) on the third page please enter the version of your wireless route. Please be very careful and sure while entering the version number of the router. 6) after entering the version dont hit enter rather scroll down a little 7) To your left you will see DOWNLOAD,under that you will see sumthing written like Firmware 8)Download the firmware file and save it to desktop,no where else 9)Now open an internet explorer page and delete evrything from the address bar of the internet explorer and type the number 192.168.1.1 and hit enter 10)It will prompt you for username and password, user name should be blank(do not type anything) and in the password type admin,and if u have changed the router password please try that 11) It will take you to linksys page 12)Click the tab in the black bar named Administration 13) Just below the administration you will see Firmware,please click that 14) click browse tab and select the downloaded file and click start upgrade 15)once the upgrade is finish,unplug the power cable from the router and wait for 30 seconds,after 30 seconds plug the power cable back Now when you will open the router page it will be full.Enjoy
warm regards Chiranjeet Mitra
Oct 07, 2009 | Linksys Wireless-G WRT54GS Router...
Lock phone and forgot unlock code
Try entering the security code. The security code is supplied in the manual. If it doesn't work, try a hard reset. If it doesn't resolve yet, try a Firmware upgrade. It may not work ( Firmware Process ) as you can have a upgraded Firmware already. In that case, try to contact the Lg Service Support. They will update the phone to its default settings and will also make the phone's lock code defaulted. Thus enabling you to only entering the default code ( which is normally 1234, 12345 or 0000 ).
Thank you Sir, Have a nice day.
Sep 24, 2009 | LG VOYAGER VX10000 Cellular Phone
I have aproblem with my RV042. I cannot access the default web page. Upon entering the default Ip it will always display the upgrade firmware unpon entering the difalut IP
Here's what you need to you may need to reset the router first if you want to access the router setup screen (default settings),
resetting the router - have a paper clip and push the button there for 30 sec. turn off the router and turn it back on.
checked the IP address also of the computer, click start run CMD and hit okay. Then push IPCONFIG and check it the IP address, you should be getting 192.168.1.100 for the IP address and default gateway of 192.168.1.1..
Let me know what happens there..
Jun 05, 2009 | Linksys RV042 VPN Router
Want to unlock Siemens Dual Phone DP450
How To Unlock Tesco Internet Phone Siemans DP450
Unlock your Tesco DP450 IP Phone to use this with other VoIP providers.
Gigaset Communications have created a process that enables Tesco Internet Phone subscribers with Siemens Dual-Phone DP450 to unlock the phone from the Tesco Internet Phone service. This will enable the phone to be used with other Internet Telephone services. This follows the recent news that the Tesco Internet Phone service is to be ceased from April 26th, 2010.
This is an approved method for unlocking the Siemens Dual-Phone DP450 defined and released by Gigaset Communications, the original supplier of the phone to Tesco. If this procedure is not followed exactly your phone might not work anymore. In this case Gigaset Communications cannot accept any warranty claims.
Unlock procedure
Your Phone should have the latest released Tesco software version, else this unlock procedure will not work.
On your handset:
BASE > SETTINGS > SOFTWARE UPDATE
Select and press OK Enter the system PIN (0000) and press OK
The base station establishes a connection to the internet or a local PC.
YES Press the display key to start the firmware update. If no update is needed, this will be displayed.
To unlock the WEB interface of the DP450, you need to enter the following service code. Please use the exact code as is described below, else your phone will not work anymore.
SETTINGS > BASE 94762001 (Now "Eeprom" must be displayed)
Insert the following number sequence: 01778 06183 06191 Press OK to finish the programming. "Saved" must be displayed on the Handset.
Then release the phone to be able to upgrade it with the latest Retail firmware version.
SETTING > BASE 94762001 (Now "Eeprom" must be displayed)
Now insert this number sequence: 04850 04351 04864 Press OK to finish the programming. "Saved" must be displayed on the Handset.
After this procedure you can upgrade your phone to use the latest retail firmware version.
SETTINGS > BASE > SOFTWARE UPGRADE
Please Note: The firmware update can last up to 3 minutes.
Your Phone is by default configured to use the Internet Telephone service, if you want to change this to set the default to the land line you need to change this in the web interface from your phone. How to do this, download the Gigaset S450 IP manual from the Gigaset web-site URL: http://gigaset.com/uk/en/cms/PageCustom ... nuals.html
Regards,
Smith Online
Apr 11, 2009 | Lands Phones
My blackberry 7290 showing "error 507"
good Days
I have problems whit my BlackBerry 7290. Wen starting it is showing "error 507". pls help me how unlock it.
post solution for me here..
thank you for help me
my regards
Mar 08, 2008 | RIM BlackBerry 7290
How do I upgrade the firmware on my DI-804V?
To upgrade the firmware on a DI-804V follow the steps below: Step 1: Download firmware from our support site. Save and unzip it to your desktop. Download Firmware here. Step 2: Access the configuration page by entering 192.168.0.1 in your web browser. Step 3: Click on the System Tools tab and then click Upgrade Firmware on the left side. Step 4: Click the Browse button and locate the firmware file that you have downloaded and unzipped. Highlight this file, click Open, and then click Start. Note: When upgrading the firmware, do not try to access the Internet and do not turn the power off. Doing so may cause the firmware upgrade process to abort, which will damage router.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
NetGear SPH200D IP Wireless Phone Logo
44 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
