Question about Kodak Office Equipment & Supplies
I can't get my projector to advance or backup using the 'clicker'.
    President:
  • Kodak Master
  • 412 Answers
You didn't specify the model projector you have, but it is easy to insert the 5-pin plug incorrectly (rotated so the correct pins on the remote are not in the correct holes in the remote receptacle). If you have done so, the remote control will not work.
Posted on Dec 30, 2010
I've replaced the correct lamp and filter to the projector but it will not do anything
Try replacing the lamp igniter that creates the high voltage to turn bulb on.
Mar 01, 2016 | NEC NP17LP Projector lamp
How do I forward the slides of a powerpoint presentation using the remote?
Make sure that you connect a cable (usually the USB cable is supplied with the projector ) from the computer to the projector. Once communication is established, normal PPT slide advancing is done by pressing the up/down arrow keys (depending on the remote control layout)
Dec 18, 2013 | Epson Projector Remote Controller...
Image/power issues
A lot of projector lamps / bulbs only have 2000hrs of expected life. that's about a year if you use it to watch TV. Do you have a backup to try out ?
Oct 25, 2013 | Canon XEED SX50 Multimedia Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
Murgee Auto Mouse Clicker Registration key please
I'd recommend that you use Asoftech auto clicker that I always use.
here the auto clicker download url
http://www.asoftech.com/auto-clicker-download.html
Feb 08, 2012 | MurGee Auto Clicker MurGee
Neither the hand-held "clicker," nor the buttons
To be absolutely sure, I would need to know the model number/name near the handle. If it is old as you say, it is probably a broken Cycle Solenoid LINK. If this link breaks (it happens A LOT on older projectors) the cycle function will not work. This is a pretty difficult repair and subsequent adjustment. You can still get the parts online at: www.microtools.com I believe they send install instructions with the parts. If you don't feel comfortable with the repair, you should contact an authorized warranty service dealer. Good Luck !
Sep 18, 2011 | Kodak Carousel 4600 Slide Projector
I just dragged this projector out of my grandma's basement. I have a new bulb and the projector appears to be in working condition except for the slide advance--the slides advance continuously. How...
There is usually a sliding tab on the side of the projector (behind the handle) that toggles between "manual" and "automatic" advance. (Some models will have a couple of pre-set advance settings between "manual" and "automatic." These usually advance the slides every three to ten seconds.) Push the tab to the manual setting--this will allow you to use the buttons towards the front of the machine to advance your slides.If moving the tab doesn't work it may be broken or jammed.
Jul 29, 2011 | Kodak Carousel 4400 Slide Projector
Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
Remote control problem
Yes, the computer won't advance the slides unless connected via the USB cable to the projector.
Mar 24, 2008 | Sony VPL CX11 Multimedia Projector
37 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
