Question about Maytag PAV2300 Top Load Washer
Maytag LAT9235AAE not agitating
Washer does everything but agitate, new belts were installed but didnt fix the problem
    President:
  • 1,304 Answers
Sounds like a transmission
sorry
Posted on Oct 07, 2009
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
Jul 09, 2017 | Maytag Atlantis MAV6260AWW Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The washer runs through the cycle, but does not fully agitate.
if no visible adjustment nut, then you need to replace new belt may be it already wornout and not capable pulling.
Mar 31, 2010 | Maytag Atlantis MAV5000
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
Maytag 6300 won't agitate durring wash cycle
HI. this is usually caused by a faulty drive assembly(agitator gear components and clutch malfunction).
I recommend replacing the agitator components by purchasing a Agitator replacement kit. and, replace the clutch assembly as well. this will fix this issue.
Jun 17, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Washer will not agitate on wash cycle
could be a belt (doubtful) or it could be the connector underneath the. if the bolt isn't tight, it could be sliding along the cutout that makes the agitator work. tip forward and check it from beneath/backside whicheverr has the easiest access to view the connections.
Dec 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
Maytag LAT9235AAE fills with water....
Pt, as long as you verified the lid switch is good, do this simple test. Get a piece of hose the same size as the one going to the pressure switch, connect it and blow into it. See if it starts agitating. If it does, there's your problem..Catriver post back.
Sep 27, 2006 | Maytag 22 Cycles Topload washer, SAV365Z
Maytag PAV2300 Top Load Washer Logo
126 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
