Question about E-Machines E17T 17" Flat Panel LCD Monitor
Monitor flickring Hi All, i am using the mercury (intel 845 gl chipset) mother board and i installed latest graphic drivers from intel site and i changed my monitor refresh rates also but my monitor gives flickering i tested My cpu with my another freind's monitor but there also gives flickering and i am sure that no magnetic devices are near to my computer and i checked the all power cables and i replaced the all power cables also but it is giving flickering, my monitor is flickering while in the time of cpu processing only in normal times it is not giving any flickering means when the red light is blinking on the cpu that time only monitor is flickering means while in the time of loading O/S,while in the time of Opening any applications that time only my monitor is flickering. plz any one give the correct solution for me. Thanks in advance kumar
  • 3 Answers
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Posted on Feb 05, 2009
Please give me his mother board driver
Hi Sigmainfotec
Use the link below to download your chipset drivers.
You just need to select your opperating system and drivers and it will start downloading.
Do not be bothered because is is an intel site, the MSI 845GEM uses the Intel 845 chipset which you will be downloading.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Chipset+Software&ProductProduct=Intel%c2%ae+Chipset+Software+Installation+Utility
Nov 23, 2009 | MSI Motherboard 845GEM-L i845GE P4 533FSB...
Driver problem
please you install substitute intel mother board 854 chiset driver
Aug 13, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Display driver for KOBIAN PI845GVM 5.0
hey u have an intel chipset mother board with 845 chipset just go to intel website and get ur latest driver directly this kobian /mercury website of ur manufacturer doesnt provide updated drivers just follow the links
for ur latest driver
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=865&lang=eng
or if u want from KOBIAN just go to this link and download graphics driver irrespective of motherboard model bcoz it has the same chipset as u have on ur motherboard just downlaod vga driver and install it will work
http://www.mercury-pc.com/downloads_list.php?productid=553
pls rate me FIXYA if i fixed ur problem
Mar 03, 2009 | Computers & Internet
Display driver for intel 845 board
http://www.soft32.com/download_173342.html
Jan 22, 2009 | Intel Computers & Internet
Hi i want graphic card for mercury motherboard intel chipset VGN 845 GL
Geoforce FX 5500 works well in this board. Make sure you buy the proper card. AGP if your board has an AGP slot or PCI-E if your board has the PCI-E slot. Hope this helps.
Dec 15, 2008 | Computers & Internet
Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
E-Machines E17T 17" Flat Panel LCD Monitor Logo
813 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
