Question about HP Office Equipment & Supplies
New ink cartridge installed, message on printer reads ink cartridge missing or not detected
  • 585 Answers
Hi my name is Eric,
I can help you with your issue ,
If using non oem ink the ink level switch may be bad or not connected,
Remove and reinstall or try another cartridge
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Posted on Oct 07, 2009
Ink cartridges Missing or damaged Officejet Pro 8500
Check with another working or new cartridge, if problem not resolved,fault with iss unit(ink supply station). check ISS cables, PCB..replace ISS unit
Jan 31, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
I get the message that the print cartridge is missing or not detected. Have tried taking cartridges out and putting them back in, replacing with new cartridges
What you could try is to remove both ink cartridges and close cover.
Turrn off printer and unplug from electrical outlet.
Wait at least 15 minutes for printer to reset.
Plug back in printer, turn on and wait until printer stop .
Install both ink cartridges.
Jan 11, 2011 | HP Photosmart C4180 All-In-One InkJet...
HP Photosmart displays a message saying "Printer Cartridge(s) missing or not detected" though I've just put a new cartridge into the machine. How do I fix this so I can print again?
Remove the cartridge.
Make sure that you removed a piece of clear plastic tape that covers the ink-jets. It's placed there to prevent the ink from drying-out while the cartridge has been sitting on the shelf at the computer store.
Re-insert the cartridge, and be sure that it "clicks" into place.
Apr 02, 2010 | HP Photosmart C4280 Aio Printer
Ink cartridges message on printer, ink cartridges
Make sure you have removed the protective clear plastic from the new cartridge.
Aug 25, 2009 | Dell 924 All-in-One InkJet Printer
I buy until now 5 hp351 colorcartridge, after few days is "dead"
Sounds like the problem is that you are refilling the cartridges. Each HP cartridge has a special chip on it that will only read the original ink supply properly. Try a brand new cartridge that has never been refilled and see if that makes a difference.
Jul 26, 2009 | HP Photosmart D5360 InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
Printer 4355show in message
may i know if the INK that you are using is a HP genuine ink cartridge??if it does clean the copper contacts on the printer and try to check also if the ink cartridge that you are trying to insert is the compatible ink cartrdiges of the PRINTER
Sep 03, 2008 | HP Officejet 4355 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
325 people viewed this question
Seeker5211
Seeker5211
