Question about Copystar CS-2030 Copier
Our copystar 2030 keeps asking for toner. We just
Our copystar 2030 keeps asking for toner. We just replaced the old cartridge with a new one. We removed the tabs from the new cartridge and when we load it up the message says "adding toner" then stops and says "add toner". It will not print or copy either. Has anyone else had this error?
  • Mike May 11, 2010
    Did you shake the toner cartridge well before fitting?Also is it a genuine toner cartridge?
    Guru:
  • 389 Answers
Can be an ensemble of the reasons:
1. The Silent sensor which checks the concentration of the toner.
2 Check pulled of you film defensive with tubas?
3 During moving the toner track can be broken or littered.
4 Can be a value-added degree to concentrations of the toner in service programme inflexion
5 Can be sensor itself to concentrations
7 Sensors can be littered
8 If it is used developer, can be violated concentration developer to toner
This in a complicated way repairs with words.Sooner whole you should apply to service,forgive, but such fault it is difficult do advice, it is necessary all look the experienced specialist, you may lose much toners and break the track of the presenting the toner, apply to service. Good luck
Posted on Oct 09, 2009
Keeps saying to add toner
replace toner. if persist use simulation 132 to replenish toner
Aug 03, 2010 | Copystar CS-2030 Copier
C710 ON A cs 2030
if it appears after replacing the toner then the toner being used is faulty
Apr 26, 2010 | Copystar CS-2030 Copier
How do i replace the toner?
Open the white door
pull bypass door towards you
move the blue lever towards you
slide lever to the side ,lift out the old cartridge
pull tape on new toner
snap in new toner firmly
push blue lever forward
close doors
Oct 27, 2009 | Kyocera Copystar CS-1820 Black and White...
Cs-2030 replaced dev. and toner sensor due to sc-710 code. still get code when turning off machine then back on. if i open and close front cover sc-710 clears. what could be cause?
check your toner catridge. specifically, where the toner drive gear meshes with the cartridge. make sure the drive gear/hub is the same shape as the little part on toner cartridge that it meshes with. sometimes, you can get a kyo-mita toner cartridge or generic, and those two things will be different shapes, therefore, not supplying toner as it should.
hth,
razors
Apr 08, 2009 | Copystar CS-2030 Copier
Hello there! This is the first time that our printer needs to have the toner cartridge changed, we dont know where to locate the old toner area
If you open the fron door you can't miss it"s a big box there is a lever you may need to release so you can slide the toner bottle out
hope that help
Dec 02, 2008 | Copystar CS-2030 Copier
C710 Code on Copystar 2030
C710 Toner sensor problem
• The sensor output voltage is outside
the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run.
Try removing and refitting drum and toner.
if this does not help you may have damaged your toner cartridge or the sensor
Feb 20, 2008 | Copystar CS-2030 Copier
Mita DC-1205 Copier
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Oct 24, 2007 | Office Equipment & Supplies
Copystar CS-2030 Copier Logo
143 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
