Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Whites are real bright and has an orange color
The tv is ver bright when we adjust the colors the whight stay's really bright. it allso has an orange color to it .
  • 585 Answers
Hi my name is Eric,
I can help you with your issue ,
 This philips TV could have a number off issues, fluid leaking from a CRT,
or the SSB or SSM boards are bad.
I tech will charge you over $350 to replace a board.
There are color adjusters in the back inside the TV , red blue green screen controls, it wouldn't solve your issue , but lowering on may make it watchable for now
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Posted on Oct 07, 2009
TV picture just turned orange suddenly, what do i do to have a perfect picture resolution again?
Well the color has nothing to do with "perfect picture RESOLUTION". Go into setup and try to adjust the colors...or amount of color...same with brightness. Also check any automatic setting for the screen or picture.
Oct 30, 2013 | Hisense Televison & Video
How to adjust picture color
To adjust color first of all set contrast and color controls to minimum,adjust the brightness to see clear picture than add contrast to get perfect black and white picture than add color to it for a good quality color picture.
Jan 22, 2011 | Symphonic ST419E TV
Colors are off on the TV. When I try to adjust the contrast and brightness, etc from the menu, either everything is orange or green or yellow.
Contrast and brightness won't fix it.You are on the right path though.You need to search around for a color adjustment.You should have numbered scales for all 3 primary colors to adjust.It should also be somewhere under the picture option.Let me know if you need better instructions.Good luck!
Aug 05, 2010 | Toshiba 42AV500U 42 in. LCD HDTV
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
The color on my tv is awful. sometines it can be bright blue sometimes orange then most times very dull in color
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
Nov 27, 2009 | Philips 50P8341 50" Rear Projection...
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Its a slight possibility that a 2.00 Part called a capacitor could be bad on the screen drive voltage source. But most likly it sounds like the Picture tubes are comming to the end of there life expectancy. If the crts are weak there is a crt rejuvinator that could possibly clean the grids off each color gun. But this is a crap shoot, as sometimes it destroys the tubes. These type of repairs are not for the handi-man or a consumer to do. There are no real user replaceable parts inside so unless your able to solder and know the HI Voltage saftey issues, you should call a pro to assist you in this repair. Good Luck
Jun 24, 2006 | Philips 9P6031C 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
179 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
