Question about GE Spacemaker JVM1640SJ Microwave Oven
Door to GE spacemaker is loose. EWill only run if
Door to GE spacemaker seems loose. Microwave and oven will only run if door is held by hand is a specific position.
  • 832 Answers
Have the door of your microwave adjusted and screw is tight, so you won't be holding it.
Posted on Oct 07, 2009
How do I check the magnetron or the capacitor?
There are three microswitches
When checking a microwave oven that seems to operate properly yet does not heat first check for 110VAC at the primary of the large transformer.
Dec 13, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
What is the serial # range for GE Spacemaker microwaves vintage 1984-1985
That would be difficult to track down, but you can use a universal door switch "open or closed " selection making it handy, some tv repair shops still may carry some parts, appliance repairman another choice.
Mar 06, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating or cooking
Use the GE trouble shooting guide from the Service and Parts envelope that GE usually hides in the unit. Remove the plastic exhaust grill and look on the left hand side for a small black envelope with white lettering held in a slot. Kind of hidden...
Nov 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Profile microwave oven will not heat! It turns on but doesn't heat... Any idea?
Hello:
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Oct 14, 2009 | Microwave Ovens
Microvent is coming loose on the bottom of mounting.
Generally, these units are held to a backing plate with a pair of screws that are accessed by removing the vent plate above the door. There are a couple of Philips screws. Inside...at each end, there is a slot head screw head on a rod. Support the unit and back these screws out. The unit will then pivot from the bottom away from the wall. Detach it and then repair the issues with the hold bracket. Warning: these units are heavy!
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - Noise while heating
Maybe you and the person from the post below could get together and help each other? http://www.fixya.com/ThreadView.aspx?prdid=489218&thid=130453
Mar 25, 2007 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
278 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
