My copier shows a F1 in the screen and will not allow me to make copys.
  • 2 more comments
  • rodneyyack Oct 07, 2009
    Panasonic fp-1780
  • rodneyyack Oct 08, 2009
    Yes.When you turn it on , on the counter display all you see is an F and a 1 if you hit the print button the display shows 88.8 and all the control panel lights come on and you have to turn off power. Once you get the F-1 back you can change it to F5 and several other numbers sometimes it will show "U-6" if you hit certain numbers on keypad. I have tried the"paper tray button,Recall button and Clear/stop button all together and all different orders no change.
    Panasonic FP-1780 had wrench showing on display but still made copies. Cleaned and serviced copier did the clear procedure I got online"Paper tray button,Recall and Clear button at same time to get to F2,Entered#5 so it shows F5,hit print button to get C000 changed to C70,hit print button display showed number 8, hit print button again,went red for a second then back to green. Wrench was gone off display. Did procedure for getting out of service mode and now shows F1 on display when power is turned on. Hit print button and all lights come on and have to turn power button off and restart, can't make copies.
  • rodneyyack Oct 09, 2009
    Panasonci FP-1780. This copier is so old I don't know if it even has the capabiitie of software and driver updates.
    Guru:
  • 1,326 Answers
Sounds like a communications error. Try unplugging it for 5minutes and restarting it, should clear right up.
Posted on Oct 09, 2009
  • 11,896 Answers
What type of copier is this? I can find you a sofware and driver download if you wish.
Posted on Oct 08, 2009
  • 13,433 Answers
Hi, could you please include the brand and model with the error message.
Posted on Oct 07, 2009
  • Ekse Oct 07, 2009
    is F1 the whole or all of the error message you receive?
Mx2700n sharp is showing f2-33
f1 33 is a finisher problem There is no F2-33 listed Copy Systems
Jul 26, 2016 | Sharp Mx-2700n Color Copier / Network...
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 03, 2009 | Minolta Di251 All-In-One Printer
Can we refill toshiba e-studio 207 Tonar Cartige ( Cartige No.T-1640D
sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
Sep 03, 2009 | Toshiba e-Studio 205 Copier
Sharp Copiers Error code : F1-14
I was making copies through the document feeder and got the F1 error, and it's blinking and I can't make copies. Any ideas? Thanks!!! Christine
Mar 02, 2009 | Sharp Office Equipment & Supplies
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Spanner Icon Shows on the pane
its a maintenance service indicator
Nov 18, 2008 | Toshiba 2060 Copier
Sharp Copier AR-5132
Generally F codes have to do with the finisher(used to be called a sorter). with the machine off, diconnect the finisher cord from the copier and power back on. This should allow you to test the copier. I'm not sure on this model how exactly the finisher cord comes out. but it should be self explanitory when you see it.
Oct 29, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
23 people viewed this question
k24674
jasbo
jasbo
