Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia lt 30 hv
Im having power problems with my tv it started flickering then went to a blue screen and then it went black my blue light on the set is on but when i try to start it mauely or with the remote their is no response pleas help the set is about year old
  • darwin360 Dec 26, 2007
    the tv was fine then it went to a blue screen telling me no signal. The CD that comes with the tv says nothing about it. I have tried reseting the channels like the technical support website said but nothing works.
  • 3 Answers
You both need to IMMEDIATELY download your warranty from the Olevia website. Read it completely. If you are still under warranty, then contact them IMMEDIATELY in writing pursuant to the warranty and demand that they fix the TV for free pursuant to the warranty. Do not accept "No" for an answer. Document every communication and contact you make, including date, time, who you spoke with (first and last name and/or employee number), and the content of the communication.
Do not delay on contacting them, because the warranty is controlled by the date you purchased the TV. If it passes, then you are totally screwed. Olevia will ignore you.
Do not buy any Olevia or Syntax products in the future. Tell everyone you know to not buy their products either.
Posted on Dec 27, 2007
Olevia LT-30 HV
power supply capacitors have failed
Feb 18, 2013 | Televison & Video
Syntax olevia LT 30 HV has sound but no picture.
I cant help you with the problem but I have the same tv without the original stand and if you are willing, I would purchase yours. If you would like to do so please email me at
Thank you.
Dec 02, 2010 | Olevia Televison & Video
Olevia tv, no power
This the common problem for Olevia TV, open up the back cover, locate the power supply board, look for the electolytic capacitors top that is slightly domed, replace them, they usually 1 or 4 that is bad, buy your replacement's at Radio Shack
Jun 06, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Where can i find a manual for the Olevia LT 30 HV
I have the manual for the lt-32. Should be pretty much the same except that it is a 32" tv. If your interested leave me your email and i`ll send it to you.
Dec 01, 2009 | Televison & Video
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
LT 30 HV Olevia Syntax No picture - blue flash
Ur video converter board is dead.
Need to be change.
Aug 15, 2009 | Insignia 37" LCD Flat-Panel HDTV
Syntax Olevia 30" LCD - blue screen, then black screen, sound is on
you have a broken inverter board. I have a LT30HV, and it had the same problem. The inverter board supplies power to the backlight. Swap it out with a good one, and you're back in business.
To test, take a bright flashlight and point it at the screen just an inch or so off the surface. If you can see your picture, then you have a blown inverter.
it may not be worth fixing it. Wait for a good sale on a new one. My inverter cost about 150, and it was a remanufactured part. Not as good as the original part as it flickers just a tad. I had to take the entire TV apart, with pieces literally everywhere. My cats loved it.
Oct 21, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 26" Flat Screen
I too had a similar problem with my 26" Olevia LCD TV, except it would flicker at different frequencies like a strobe light.  The flicker would even increase in speed, giving the visual illusion that the TV was about to blow up.  After several power-on, power-off, unplug, repeat, I was about to give up and think about looking for another TV. I saw your posts here and both of you "hit" the TV and it seemed to fix it, right?  Same here -- I gave the TV several good lateral "whacks" upon the outer edges of the unit!  The whacks weren't violent, just slightly "jarring" and after that, the TV stopped the flickering.  As you've said, it is quite juvenile to go beating on electronics, but interestingly enough, this method of "fixing" the electronics does at least seem to have an effect if done correctly.
I do also note that I went into the TV's menus and intentionally set the "Back Light" setting to "Dark" and "DNR" to "Low" to perhaps attempt to lesser drive the back light.  Since the beatings and then the much more rational idea of changing the menu options, the TV has worked, at least for a while now, relatively well.
Dec 31, 2007 | Olevia LT26HVX 26 in. LCD Television
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Olevia LT37HVS 37 in. LCD HDTV Logo
515 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
