Question about Panasonic KX-TGA650B 5.8GHz 2 Line Expandable Handset for the KX-TG6500 Series 037988474806 Phone
Panasonic KX-TGA560M phone disdplay is blank
My Panasonic KX-TGA560M phone disdplay is blank and I've cleaned the battery contacts.
SOURCE: Screen gone blank
I had the same fault with the handset losing it's display, phone worked great but could not see to access internal phone directory.
To strip down the phone you need a very clean hard plastic/granite
work surface and a small philips screwdriver and a small flatblade screwdriver.
First of all remove the battery cover and the batteries, put them in safe spot on the work surface (Tip: take the top cover off an aerosol tin to use for holding the screws and small parts you remove)
Remove the front facia by gently teasing it away from the body of the phone, there are 2 plastic lugs either side of the battery compartment, ease them towad the edge of the casing to release the front facia, it should then unclip easily with your thumbnail.
Near the edge of the phone you will see 2 small screws, remove them carefully and set them aside, please note these are longer than two other screws you will encounter later in the disassembly.
Seperate the two main parts of the case from the battery compartment end of the phone and work towards the other end, there are two release points on the outside of the casing, gently insert a small driver into the recess whilst applying a small amount of lifting pressure between the two casing halves and it should spring open. (Note that the case hinges on a clip at the top edge of the phone which helps with its re-assembly later.)
Please be aware that the speaker wires are soldered to the main board and should not be disconnecetd or cut!!!
At the battery end of the phone is a small strip of white plastic tape covering two short screws, these hold the cradle charging contacts to the circuit board, remove them with the metal contacts and keep them safe.
With a little coaxing the rest of the phone should now come out of the casing. Be very carefl not to touch any of the gold contacts on the circuit board or the buttons may not work, you may gently clean these using a dry microfibre cloth. DO NOT SCRUB THEM, simply rub gently a few times.
Unclip the display holder andnote the earpice comes loose, this can be fed through the plastic holder byturning it sideways and pressing it through. DO Not damage wiring!
You should now see the tiny ribbon cable on the display itself, either side of it are a thin white plastic lug which can be slid carefully away from the edge of the display to release the cable. Remove cable gently and re-insert it back into the connector it came from, ensuring it is fully home and is perfectly aligned at right angles to the display, then carefully slide the retaining lugs back into place which will lock the cable back into place.
You can now re-assemble the phone, carefully.
It worked for me, hopefully it should for you unless the display is damaged prior to or during disassembly.
Posted on Mar 09, 2009
cnavarro
  • 2460 Answers
SOURCE: need to access voicemail with no password-panasonic KX-T230 phone
Find the password to mailbox 999 or call a Panasonic dealer.
Carl
Posted on Jun 16, 2009
  • 1126 Answers
SOURCE: I need a manual for panasonic phone KX-TG1311
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones.75500
The closest that I could find was kx-tg1031. Perhaps you will have better results. All of these are in english.
Posted on Aug 31, 2009
  • 19 Answers
SOURCE: operating manual for Panasonic phone KX-A126CE
Had an LG tv manual shipped to me 4 free. In the meantime their manuals were available for viewing or downloading on-line. Sure panasonic does the same.
SOURCE: Panasonic cordless handsets all say line in use
Return to the manufacturer for replacement. I've spent hours on this and have had my line tested. It's a base station fault.
Posted on Oct 02, 2010
How can I get the code to retrieve messages from a Panasonic KX-TGA560M?
The KX-TGA560 isn't an answering machine. If you have a separate answering machine connected to your phone line, please consult its documentation. If you're subscribed to a voicemail system provided by your telephone company, please contact your telephone company for instructions on accessing their voicemail system.
Jun 12, 2012 | Panasonic KX-TGA560M 5.8 GHz Cordless...
How do i check my voice mail
The KX-TGA560M isn't an answering machine. If you have a separate answering machine connected to your phone then please consult its documentation. If you still have problems, please repost your question specifying the make and model of your answering machine.
If you're subscribed to a voicemail system offered by your telephone company, please contact them for instructions on accessing their voicemail system.
Mar 29, 2012 | Panasonic KX-TGA560M 5.8 GHz Cordless...
Display on the cordless is completely blank
You could buy a new handset from :-
http://cgi.ebay.com/PANASONIC-KX-TGA560M-5-8-GHz-CORDLESS-HANDSET-/230557643171?pt=LH_DefaultDomain_0&hash=item35ae4e71a3
The cost of the handset is less than $25. If the unit is under warranty ( less than i year old ), you could contact the service center and get it replaced without any cost.
The average cost of repair is around $75 on this set for display. That is one of the reasons why we recommend buying a new handset. This is a common problem on most of the handsets. We did everything that we could - swapping batteries and making sure that it is properly registered.
I know, it is not a good new, unfortunately there is no reset button unless you take it apart and look for a loose wire or connection. That is the only possibility.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 02, 2011 | Panasonic KX-TGA560M Cordless Expansion...
Hot do you fix Panasonic KX-TGA560M 5.8 GHz Cordless that has nothing displaying on the screen?
Cannot hear from handset or earphone, can only hear from speaker phone. What can be the problem.
Aug 24, 2010 | Panasonic KX-TGA560M 5.8 GHz Cordless...
Caller id
the digital answer machine did not torn on? Why?
Feb 05, 2008 | Panasonic KX-TGA560M 5.8 GHz Cordless...
Can't hear clearly
I have opened the phone up and changed the wires for the Speaker phone and the ear speaker. As long as I answer the phone using the orange SP-Phone button it works well.
Dec 23, 2007 | Panasonic Lands Phones
No dispaly on screen.
Three possibilities. 1) The LCD screen is cracked from a fall or hit etc.. It can be visible or a small crack hidden on and edge or corner, only visible after taking out the display. 2) The phone was exposed to moisture or high humidity long enough for corrosion to start. This could have happened many months ago. The corrosion has finally effected the LCD. If you're up to disassembling the phone you can clean the LCD connector with rubbing alcohol and a tooth brush as well as clean the LCD cable itself with a pencil eraser. Typically the LCD is held in with a little 2-color connector that you open with a tiny screwdriver or other tool by carefully prying off each side of the connector a little bit. (1-2mm) when you are done just slide the lcd connector in all the way and push the connector back in. 3) It's unlikely but the LCD can just stop working. It's not worth paying $30 to $50 for a new one. Just replace the phone.
Jul 12, 2007 | Panasonic KX-TG5622M Twin Cordless Phone
Lands Phones Logo
159 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
