Question about Jenn-Air JGS8860BDP Stainless Steel Gas Kitchen Range
Control pad not working code ee-214 m-214 - Jenn-Air JGS8860BDP Stainless Steel Gas Kitchen Range
2 Suggested Answers
SOURCE: I have a Jenn Air 'slide-in' electric
The unit has a bad touch pad
Posted on Mar 05, 2010
Im using emachines n 214... touchpad is not working why?
Go into the control panel, find the deviceicon1.png manager, and then find the touch pad in the list. Right click on it and select enable. Or Function key (FN) + F7 should enable the touch pad.
Let me know if this helps,
Sincerely,
Hunter Quinn
IBM Help Desk
Dec 04, 2014 | eMachines Computers & Internet
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
Panasonic CWXC203EU the unit is flashing error code EE and only when you unplug it shuts off the control do not work blows s a littlle cold air but after a shor time it shuts off
Hi.
EE means energy efficiency. hen EE is displayed there can be a defective thermistor or insufficient ventilation.
The following works on some A/C system: "When EE is displayed, press "energy save" and "zone control" simultaneously for about 5 secs"
Try also testing the system in auto mode, check ventilation and if possible test thermistor by reading impedance with a multimeter.
If when EE is displayed the unit also becomes non-responsive and does not turn off, then the problem may also be a defective controller board. Other parts, included the ones mentioned before, must be tested before replacing the control module.
Regards.
Ginko
Aug 11, 2011 | Heating & Cooling
I have a fujitsu invertor AOT54LJBYL and the key pad comes up with EEE
When EE:EE is displayed on remote control , press "Energy Save" &"Zone Control" buttons simultaneously for longer than 3 secs. The error code will then be displayed on the LCD.After getting error code, please write here to get solution. Thanks.
Feb 04, 2011 | Heating & Cooling
We have ducted air which cuts out and shows on the control panel where the clock is says EE.EE
When EE:EE is displayed on remotecontrol , press "Energy Save" &"Zone Control" buttons simultaneouslyfor longer than 3 secs. The error code will then be displayed on the LCD.Then write again. Thanks.
Jan 31, 2011 | Fujitsu Heating & Cooling
CODE ERROR E.EE
code will then be displayed on the LCD.Thanks.
Jan 15, 2011 | Fujitsu Heating & Cooling
Fault codes ee214 m214 jenn air ele range
how to solve fault code EE-214 M-214
Jun 07, 2009 | Kitchen Ranges
Jenn-Air JGS8860BDP Stainless Steel Gas Kitchen Range Logo
344 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
