Question about Refrigerators
Compressor short cycles and is noisy - Refrigerators
    President:
  • Refrigerators Master
  • 1,922 Answers
Your compressor is low on refrigerant
Posted on Oct 07, 2009
Unit has a loud humming sound that changes in pitch as the unit runs
Could be a noisy compressor. The sound changes as the compressor cycles.
Nov 16, 2016 | Heating & Cooling
I have a new Delonghi portable AC PAC N115EC (11,500BTU), is it normal for the compressor in this particular A/C to be cycling on/off every 2 to 3 minutes?
If the room is cool, it sounds like the unit is operating correctly. It could be short cycling because the unit is over sized for the room being conditioned. if you can, increase to size of the load by opening a door into another room. As long as the refrigerant pressures equalize from high to low side internally and the compressor doesn't start up under load, you should be fine
Sep 10, 2016 | DeLonghi Heating & Cooling
Why does the compressor starts off with short cycles then kicks on?
Could be a compressor start relay, overload and run capacitor. What is the model number of the fridge?
APPLIANCE 911
Dec 07, 2015 | Refrigerators
Refrigerator noisy when running
It sounds like one of the shock absorbing boots on the compressor has gone bad. I would start there.
Best,
Joe
Jan 31, 2014 | GE Refrigerators
Compressor is noisy
You didn't mention how old the unit is. If your condenser is clean then you probably have a warped valve in the compressor. If the unit is cycling on and off and maintaining the proper temp check for vibrations.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Hi, I have a question about anti-short cycle, can anyone explain what exactly 'anti-short cycle' is? If I am running the air conditioner's compressor with a soft-starter (1-phase and 3-phase), does...
Anti-Short-Cycle Timers - Airotronics
www.airotronics.com/products-antishortcycle.phpAnti-short-cycle timer prevents premature cycling of compressors in refrigeration, air conditioning and heat pumps, thereby reducing nuisance tripping of fuse or circuit breaker.
Feb 14, 2018 | York / Cam-stat Anti-short Cycle Timer...
Compressor short cycling
If the condenser fan works , try replacing the compressor relay and overload (it;s the most common problem) but if the compressor still goes on and off , probably is burnt or jammed and has to be replaced.
Nov 03, 2009 | Refrigerators
Making loud noise,like a gun going off model 106.64939400
Check the fan motor at the compressor for a foreign object in the blade or a out of balance blade.
Oct 09, 2009 | Whirlpool Refrigerators
If the compressor is run off of a relay then you could install a delay timer to prevent short cycling.
http://www.climatedoctors.com/items/item.aspx?itemid=429504
Jun 04, 2008 | Dometic Heating & Cooling
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
