Question about Pentax Optio E30 Digital Camera
Power problem When I put batteries in my camera it either comes up battery depleted or wont turn on at all.
    Brigadier General:
  • 11,967 Answers
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Posted on Oct 07, 2009
Why doesnt my camera want to work
hello,
have you tried turning it off and then on?
or remove the battery for a few minutes and put it back in then power it up,
or your camera might have depleted the battery power,try recharging or replacing the batteries
good luck
Mar 23, 2013 | Gateway Computers & Internet
"Batteries Depleted"
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 02, 2009 | Pentax Optio E30 Digital Camera
Blackberry pearl camera light wont turn off
I solved it!! All I did was take the battery out for about an hour, put it back in and charged it for an hour, then turned the phone on and it has worked ever since.
Jun 25, 2009 | RIM BlackBerry Pearl 8100
My pentax m20 optio wont turn on.. it says battery deplete..
Hi there - these are older posts, but I just experienced this problem (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Apr 21, 2009 | Pentax Optio M20 Digital Camera
Camera will not function
Try a new battery in the camera, if that does not work, decide if the camera is worth sending to canon to see if they can work out the proublem. Though this is likely to be costly, you maybe better of buying a new camera instead.
Jul 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Battery depleted message after i just replaced batteries
hi there,
may i know the exact maker/model of your camera & the brand of battery you use..
`jack
May 24, 2008 | Pentax Optio M20 Digital Camera
Brand new pentax E35
EINAI SKETH MALAKIA H PSIFIAKI
Jan 31, 2008 | Pentax Optio T20 Digital Camera
Battery depleted
Sounds like the battery might be defective/worn out. If it's AA batteries (a.k.a. R6) try with a pair of good-quality alkaline batteries to see if it works then. Cheap batteries often doesn't have enogh "umph" to power cameras.
Dec 20, 2007 | HP Photosmart 735 Digital Camera
Can't get my camera to turn on
Try rechargable batteries or Duracell. Other batteries may not have sufficient charge.
Aug 24, 2006 | Pentax Optio S40 Digital Camera
Pentax Optio E30 Digital Camera Logo
108 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
