Question about Solis Palazzo Espresso Machine
Steam/water valve leaks water, only fills coffee to 50%, help? I have completely removed steam valve assembly to clean and reassemble. Leak persists, suspect o-rings?
  • 1,089 Answers
Hi
If your water valve is cream or black colored, you need a new manifold. They will get hair line cracks if you steam, but don't cool them down after steaming by running cold water through them. If you have one of the new brass(silver) manifolds it could be your O-rings but i doubt it.
Posted on Nov 15, 2009
  • 832 Answers
Your Solis Palazzo Expresso machine needs immediate cleaning. It is full of coffee deposits from
its grinding operation. Have it cleaned 'System Cleaning".
Posted on Oct 07, 2009
Steamer not working
Try this push in on the steam knob after it is turned on if that works the steam valve assembly needs to be replaced.
Sep 07, 2014 | Saeco ODEA Coffee Makers & Espresso...
Delonghi Magnifica My steam arm drips when I make coffee.
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
When you press the coffee button the machine grinds the beans, but then the water comes out the steam wand... please help
The problem is a very frequent one a small scale part have been moved and it stack to the water steam valve and it blocking it from closing completely. So when you make coffee the hose of water for coffee is in parallel with hot water steam wand and since the valve remains partially opened the water for coffee find easy escape from steam wand.
So we suggest to perform one more descale and it may need twice hopefully this small scale part to be dissolve a little bit more in order to pass thought the steam valve and thus the valve can close again completely. If you are not so lucky the part remain on the valve then only solution is to disassemble the machine thus clean the steam valve manually. In this solution you may find out that the valve o ring might be damage and thus the leak.
here is the link with steam valve parts and this the parts diagram of the machine and here many more for your machine
Aug 15, 2011 | Saeco Magic Comfort Plus Espresso Machine
WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE ALSO, HOW DO YOU DECALCIFY UNIT? iS THERE AN ON LINE MANUAL?
Below are solutions for a leaking coffee maker and how to decalcify the machine?
Tools and Materials needed to fix this problem are as:
* White Vinegar * Fresh Water * Volt-ohm Meter * Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
1) Remove the machine's water reservoir. 2) Empty all liquid from the reservoir. 3) Fill the reservoir with warm water. 4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved. 5) Return the water reservoir to the machine. 6) Turn the machine on. 7) Set the large container underneath the steam wand. 8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened. 9) Open the steam valve according to the manufacturer's instructions. 10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected. 11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing. 12) Return the water reservoir to its normal position. 13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
I hope the above helps....
Good luck.
Jun 22, 2011 | Jura Capresso Impressa S8 Coffee Maker,...
My Titanium leaking water. Under it
The steam valve assembly that the steam knob on the right hand side connects into is probably faulty. When you're steaming if you hear hissing coming from behind the knob then this indicates the connections into this assembly are leaking steam, and also hot water, which is why you're getting puddles under the machine. You can get a replacement steam valve assembly that fixes some issues with the original (part code SVM-17, available from www.partsguru.com) and will prevent the leakage, or you could simply try opening the top of the coffee machine and removing the tube that runs from the boiler into the steam valve. It has two o-rings that provide the seal where it connects into the steam valve assembly, and if you lubricate these with a food grade silicon lubricant it may fix the problem. My Gaggia is 7 years old so I decided to replace the whole assembly which costs about $50 and that solved the problem completely.
Apr 04, 2011 | Gaggia Titanium Espresso Machine
Gaggia titanium. The water and steam are all going through the brew head instead of coming out the wand when I need it to. I have cleaned everything, used a pin to clean the wand (it didn't need it) ONE...
This is hard to picture. The only way water can come out the brew spout is if the brewing mechanism inside in the position to make coffee. The only way to get that mechanism into that position is to either select one of the three coffee buttons (you'd hear the grinder run, then you'd hear the motor putting the brew mechanism into place and then the pump start and water would then come out the brew spout. OR to select preground coffee and then select one of the three coffee sizes - in that case you wouldn't hear the grinder but you'd still hear the motor turn the brew mechanism into brewing position and then start the pump.
When you simply select hot water and then open the steam valve - I can't imagine any possible way for water to come out the brew spout.
Now if you mean that you don't see any water come out but water is leaking inside the cabinet and ending up in the drip tray - then that would mean a leak inside the machine. It could be the valve that the brew group locks into when it goes into brew position (you see this valve in a little recess behind the brew mechanism when you take the brew group out to clean it). Or it could be a leaking steam valve or hose inside.
You might try getting a flashlight and a cleaning brush - take out the brew mechanism and then clean around that little nozzle/valve that is in the recess just the left of center behind where the brew mechanism was. That valve should shut when you are not in brew position and not allow any water out - but it may be gummed up with coffee grounds.
If you are feeling brave - you would need a deep socket and a lot of patience with a small breaker bar (a ratchet head is too big to fit in there) and you can remove that nozzle/valve and then clean it or replace it. But it is very slow going to remove it (there must be some special tool they use at the factory). I had just the right size deep socket (like what you'd use for a spark plug in a car) but there wasn't room for a ratchet so I had to use a small breaker bar and I could only turn the valve about 1/4 turn at a time then I'd have to reposition the socket to do another 1/4 turn. It took 5-10 minutes to remove it - then it was easy to clean. I think you could clean it in place with a stiff bristle brush and some q-tips.
I don't know if that valve is the problem - but that's the only thing I can think of that would have your hot water and steam running into your drip tray instead of out the steam wand.
Oct 26, 2010 | Gaggia Titanium Espresso Machine
Dripping water from frother during coffee making, leaks water under unit - mixed with darker colored residue
Check the small chamber behind the white plastic valve, that might be filled with coffee grounds and water. For the leak while making coffee the steam valve needs to be rebuilt or replaced.
Nov 28, 2009 | Saeco Incanto Sirius Fully Automatic...
Gaggia color leaks
Remove the filter and the 2 allen wrench screws that hold the diffuser in place, then carefully remove the spring and valve seat which is probably not in there as they should be, make sure they are seated correctly and re assembly machine. At some thine there was a massive surge of pressure and that moved the valve seat out of place.
Aug 15, 2009 | Gaggia 102534 Espresso-Color...
Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Jun 20, 2009 | La Pavoni Espresso Si PAB-16 Espresso...
Leak in steam wand
Remove screws in the grinder(2), then the one in the back you will need a long screwdriver for that one, there is one under the water tank, and there are 2-3 in the front of the machine behind the door.
Jun 08, 2009 | Saeco Incanto Classic Espresso Machine
Solis Palazzo Espresso Machine Logo
190 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
