Question about E-Machines eMachines T3830 PC Desktop
Need to know hot to start emachine el 1200 in safe mode
  • 35 Answers
Depends on your operating system and bios i think.
you cant do it any harm...honest...just press f6 or f8 i think as it boots and a screen will show up asking what you want to do next?....read the screen and follow the intructions as there can be a few choices to go for.if you dont get the screen just SOFT restart untill you find the f-key that brings up the boot menu by pressing together CTR,ALT & DELETE at the same time to re-boot and then hold down another choice of f-key untill you hit the boot menu...hope this helps :)
Posted on Oct 07, 2009
Prende pero por un rato y luego la reseteo y ya no davideo
make sure that their is no cd in the drive and try booting in safe mode by hitting the function key F8 and choosing safe mode and if it works then shut it down and restart it again. good luck.
Nov 13, 2015 | Computers & Internet
How can I restore my emachine el1200_06w without recovery discs
Boot in safe mode (Press F8 over and over while your computer is booting up). From there, go to your device manager and roll back the driver on this device.
Device Manager is in control panel, hardware and sound, then it's at the top under Devices and Printers.
Apr 08, 2013 | eMachines E Machines El 1200-06W Desktop...
I have an emachine el 1200 07w and I keep getting restore failed 0x00000070. What do I do?
Remove any DVDs or CDs from the optical drives and then unplug all peripheral devices except for the keyboard and mouse. Click the "Windows" button and then type "eMachines recovery management" into the search box. Click on "eMachines recovery management" in the results list and then click the "Restore" tab. Click "Password Settings" and then type a new password into the text box. Click "OK" and then click "Restore System to Factory Default". Type the recovery password into the "Password" text box and then click "OK". Click "Next" To start the recovery process. Click "Finish" and then wait for your computer to restart. This procedure could take several minutes. Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings.
or if you are running XP If you set your machine back to eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order.
You should get rid of this virus with an effective virus remover.
You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html
If you know when you got the virus, you can do a system restore to a time before the virus was on your system.
This article tells you how to run it from safe mode http://bertk.mvps.org/html/safemode.html
Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009.
More information here http://www.ask-the-computer-doc.com/comp...
If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one.
You might also try a Windows repair install if you have the operating system disk. Follow the directions here for XP http://www.michaelstevenstech.com/XPrepa... Source(s): http://www.ask-the-computer-doc.com/comp...
Mar 10, 2013 | Computers & Internet
My emachines el1360 doesn't recognize cd/dvd
Try going to safe mode. Restart your computer and tap f8. Use the arrow key to highlight safe mode, and once you are inside safe mode. Try running the dvd or insert the sd card. If it runs well, then install RadarSync or any automatic PC updater then update the drivers. You can also manually update them by going to the website of your computer's manufacturer. Look for support and download.
Feb 24, 2013 | E-Machines Computers & Internet
I need help recovering my EL 1200 emachine, when I boot it up it says that PXE-E61: Media test failure, check cable. I don't know what it is talking about. What can I do to get booted up. I don
check all data and power leads that attach from motherboard to your hard drive make sure they have dust free secure connections
if its a flat 40 pin ribbon type it will be the first to fail
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
Jul 15, 2012 | E-Machines eMachines Desktop PC
Wan to hook el1200 to tv
search for your el1200 manual on the internet. You maybe find it on el website.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Emachines el 1200 ram upgrade how to install ram when hidden by optical drive?
you will need to remove the optical drive first to access it...take your time and remember in general you do not have to use force on computer parts...force = breaking which equals bad.
Jan 24, 2010 | E-Machines eMachines Desktop PC
Inspiron 1200 "Fatal Error" , cannot F8 into safe mode
Press "F8" while booting up. It should give you an option to go to safe mode.
Jun 29, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
Black screen
- I had the exact same problem with a eMachines W340UA and other machines. I'm not sure what this does, but I resolved it by booting into Safe-Mode. Upon successful boot into Safe-Mode (without Networking), I restarted the computer in the normal mode and it for then after worked. Please try this; though I can make no logical statement as to what occurrs or what gets fixed, I have had this method work on several machines.
INSTRUCTIONS:
Fire up the machine, after BIOS postings, continually press the F8 key. From the list of startup options, choose "Safe Mode (Without Networking). It should boot up in this mode.
After the successful boot, restart the machine and allow it to boot in normal mode. If all goes as it has for me, you will successfuly boot into Windows.
P.S: If anyone knows where the coin battery is on an eMachines w340ua laptop, and hot to get to it, please let me know. Thank you and I hope this helps!
Sincerely;
Glenn T. Kitchen
admin@consultingVisions.com
Oct 16, 2008 | Computers & Internet
EMachine ailment
Fo you have the recoveryy disk?[May be called something else by E Machines
Dec 30, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines T3830 PC Desktop Logo
115 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
