Question about HP Office Equipment & Supplies
Paper jams what is causing paper jams
  • 105 Answers
Usually the paper pickup rollers.
Posted on Oct 07, 2009
What would cause paper jams in a hp 4100 printer
Where is it jamming. Printer this age could have fuser issues, worn rollers that are not picking up properly. Is the jammed paper crinkled up or does the printer stop before damaging the paper? If paper is not damaged, the cause is usually in the paper pickup slipping and causing the printer to think that the paper is either too long or too short. Clean all the rollers in the paper tray cavity with a damp cloth.
Sep 05, 2014 | HP LaserJet 4100 Printer
Paper jam machine feedshift
Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams.
May 24, 2013 | Toshiba E-Studio167 Copier
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
Paper Jam light is on and there's no jam anywhere. What do you do?
A paper jam notification can be caused by two things. One a hard jam, paper stuck.
Two, If the paper does not reach a flag or sensor on time, the printer knows that a jam has occurred.
Most likely, you had a paper pick problem caused by dirty rollers or maybe the paper is held to tightly by the paper tray. Also a static charge on the paper can sometimes cause sheets of paper to stick together.
Don
Dec 09, 2009 | Dell 1720dn Laser Printer
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
PRINTER DID NOT TAKING PAPER AFTER PRINT OPTION AND PRINTER STOPS AFTER 2INCHES PAPER
hi
I guess its a coz of paper jam in your printer.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new **** of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
  • http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
hope u will b helpffull
thankyou.
May 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
False paper jam message
PRINTER TRY TO PICKUP THE PAPER,BUT PRINTER CAN'T.THE CAUSE OF THIS ERROOR IS FAULTY PICKUP ROLLER & SEPRETION PAD.SOME TIMES PAPER TRAY CAN NOT BE OPEN WHEN WE PUSH IN,IN THIS CASE PRINTER SHOWS PAPER JAM
VIJAY THAKUR
Jul 01, 2008 | HP LaserJet 2430dtn Printer
Frequent paper jams.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new ream of regular 20 lb copy or laser paper.
  • Don't Overload
  • Check the Paper
Nov 04, 2007 | Samsung ML 1710 Laser Printer
321 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
