Question about GE 30 in. JGP326 Gas Cooktop
The electrodes click about once a minute after all burners are turned off.
  • drayton_wear Oct 07, 2009
    I unplugged the electrical cord. I have disassembled the cook top. I have cleaned each part, and now I am waiting for everything to dry thoroughly. If the problem persists after reassembling every thing, what should I replace? (after trying each eye individually to isolate which one has the problem).
  • 10,515 Answers
If they are firing when the burners are turned off:
It is likely that either a spark switch or your module is shorted. The spark switches are located below each knob and you would have to disconnect one at a time to see which one is causing the problem. The mostly likely culprit would the the module itself. Unfortunately, all parts are inside the cooktop and involve removing the top cover to access inside the burner box to do any testing or exchanging of parts.
If they are firing only when the burners are turned on:
You either have an electrode on one of the burners that is not sensing the flame properly or you have a bad module. Use just one burner at a time to see which one is causing the electrodes to continue to click. Once you've determined which one it is, clean the spark tip (electrode) with something coarse like high grit sand paper or a tooth brush. If the problem still persists then you need a new spark module.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 07, 2009
  • taran_2005
    taran_2005 Oct 07, 2009
    Thanks for your response!!
    As i said, my First target would be Spark Module.There was one scenario, where one of
    those switches got wet and was completing the circuit to the spark module
    causing it to fire off sparks.
    There is one diagram :-
    http://www.applianceaid.com/images/typic...
    The above one is wiring diagram that would help you.You can order the part at :-
    http://www.appliancepartspros.com/Applia...
    Note - Make sure gas burner is all set and working fine.
    Let me know, if need further assistance.
    Hope i helped you.
Have a thermador psc364gdzs the spark does not work for the gridle
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
Aug 29, 2017 | Thermador Cooktops
One of burners can not ignite only having clicking sound.
First you need to brush out the end tip of the sparking electrode and the burner metal part facing the electrode so they can create a spark. If not any result the you should remove electrode and check if the ceramic cover is broken and the sparking goes in wrong way and you will need to replace it.
Sep 10, 2011 | Jenn-Air JGC8430 Gas Cooktop
Spark module wont shut off once it has ignited. Do I need a new one
I would clean the electrodes on the burners really good, sometimes they seem not to sense heat from the burner and will not turn off the ignition system. Other times I fond bad grounds to the cooktop or outlet that can cause the same issue. The electrodes since heat from the burners to shut down the inanition system, also with out a good ground this system is impossible to work correctly.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 21, 2011 | GE Profile JGP636 Gas Cooktop
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Gene
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
When the burners come on the electrode keeps clicking. If I unplug it I can light it manually
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Mar 28, 2011 | Cooktops
Miele LP cooktop: we turned the power to the range off. when we turned on again it didn't ignite (it has power!)
Hello
Keep the air holes around the burners free of debris and grease by clearing out the holes with a thin piece of wire or a toothpick. Cleaning out the holes helps the ignitor light the cooktop
Listen for the clicking sound of the ignitor, then turn off the burner if you don't hear the clicking.
Turn the burner to the "Off" position, if you continue to hear the ignitor tick after you've lit the burner. Turn the burner back on to relight it. Ignitors normally make a brief series of electrical clicking sounds when you turn on the ignitors.
Let the ceramic igniter dry out if it has gotten wet and the burner won't ignite. If the igniter isn't wet, clear out the little holes in the burner by chipping out any blockage with a straightened paper clip.
Clean the electrodes if the burners still don't light. The electrode is in the burner base. Clean the metal part with a soft cloth. You can use emery board on the metal part but not the white ceramic part.
Nov 03, 2010 | Miele 30 in. KM443 Electric Cooktop
Electrode sparking
Here is a tip that I wrote that will help you to find out why the sparker keeps on clicking...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 29, 2010 | Fisher and Paykel GC36 Gas Cooktop
One of the igniters does not click. they were wet and popped the breaker over a week ago . all but one now clicks and lites burners. it was sparking a weekago and blowing the breaker.
Make sure the area of the burner base around the spark electrode is clean (use a fine sand paper). The little hole for the gas is open (use a paper clip). You won’t see a flame unless the burner head is on. If this doesn’t help, check the bottom of the spark electrode visually. Make sure the wire is attached to the electrode and is not loose (pull it a little bit.) If the wire or the electrode is damaged, replace it ($25). If not, locate the spark module and switch the connection with another one (they are different colors). If you get flame on the same burner, but not on the other one, replace the spark module ($60). When you work with electrical components, turn the breaker off. When you test, turn it on. Good luck.
Sep 14, 2009 | GE 36 in. Profile JGP962SECSS Gas Cooktop
Romvoing the top of my Whirlpool Cooktop
first thing is the spark module(ignitor-- your referring to) is probably good and your electrodes are damaged. more then likely the problem. when you turn on one burner they should all spark( 1 module controls all 5 electrodes) so lets check that, first. when you turn on any/all burners do you at least hear clicking??. theres a switch under each **** that turns on the spark(erhaps one of them is bad. think of the electrodes as spark plugs on a car, they spark the same way, ck to see that they are clean(free from rust and carbon build up).using emory cloth or a woman's finger nail file try "sanding" down to a shiny surface the very tip of the electrode protruding out of the burner head.look for cracks in the porcelin housing around the electrodes this will lead to miss fires of the electrodes
Mar 11, 2008 | Cooktops
GE 30 in. JGP326 Gas Cooktop Logo
70 people viewed this question
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
